Will these rims fit my car?
M88JCP Dec 30, 2009
  1. M88JCP
    M88JCP Member
    88
    Hi
    I'm looking at buying the below set of genuine alloys for my car, the only thing is will they fit my car, as they a width of 245 yet my standard wheels only have a 225 width?
    Part no.8T0 601 025 E
  2. b19ctr
    b19ctr The King of Cannock
    650
    56
    thats the tyre width you need the wheel width and the ET to work out if they will fit
  3. NY_Sportback
    NY_Sportback Member
    58
    if these are from and A5 or a B8 A4 then they will fit but the bore is 66.6 and our cars are 57.1 so you will need centering rings or they will wobble, also the a5 offset is usually around ET33-37 so they will definitely rub on the fenders
  4. Lee_R
    Lee_R Active Member
    2,499
    12
    simple answer.......no! A5 wheels dont fit an A3
    Tyres are way to big, even if you change them to 225's the offset will push them out of the arch so will look silly on the A3
  5. M88JCP
    M88JCP Member
    88
    o.k thanks, i'll stay clear of them :notme:
  6. lundoz
    lundoz Member
    80
    Hi! Nice looking rims dude! Anyone knows if you fitt a ET 35 on a audi a3 sportback 2010? I think its original ET 45 or 55. Looks so much better with the rims abit more sticking out :) Thinking of buying the S3 235/35/19
  7. Kivinen
    Kivinen Member
    39
    It's the wheel width and offset that counts.
    ET35 wheel can be more inside than ET50. Just offset number does not tell you anything.
    http://www.1010tires.com/WheelOffsetCalculator.asp
    Check stock width and offset. Then estimate how much there is room to take wheel out. Use calc to check new better size.
  8. PW-Motorsport
    PW-Motorsport Member
    396
    The part number confirms these are from a A5 the spec is
    8.5x19 ET29.
    As correctly suggested above the spigot ring size will be too large @66mm and the offset will be too low.
  9. N8
    17,163
    718
    So NO, a NO go.
  10. Audi Partner
    Audi Partner New Member
    I am wanting to purchase teh TT version of this alloy for my A3
    I have an A3 (8P Chassis) and I want to put some some TTS alloy on them they are 245/45/18 offset 52 width 9J. Are these wheels to wide? or can I put some 225 tyres on them and squeeze them on?
    help
  11. N8
    17,163
    718
    TTS alloys are different, yes you can run a 215 or 225 on it, but you will need a 10mm spacers to clear the struts.
