will these lights fit
S3 chj Jan 24, 2008
  1. S3 chj
    S3 chj Member
    306
  2. jeffers999
    jeffers999 got boost
    390
    yep pretty sure mate think ya got to mod the wings a little on the inside a little tho ...
  3. S3 chj
    S3 chj Member
    306
    dont mind cutting the wing
  4. jeffers999
    390
    I dont mind watching either lol ,, im sure someone will be along soon with more info i could be wrong but i heard it takes a little cutting...
  5. mattys3
    mattys3 vorsprung durch technik
    26
    i really wont some of them my self but the xenons any idea of the price of them i dont really wont the hid kit.
  6. mattys3
    26
    there was a post on this the other day with pics do a search on it.
  7. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    Yeah you have to cut away a little of the wing, nothing too taxing though...
    As you look at the wing with the current lights installed; there's a 'crease' where it folds in behind the indicator portion; which comes to a small piece of wing that sits behind your indicator, that's the bit that needs to be trimmed. It's not difficult or particularly risky so long as you take your time and work to the rule "you can take it off but you can't put it back on" - once cut you'll just need to seal the bare metal on the cut edge to prevent rust; but you can use whatever you like to do that as the edge will be hidden.
    You'll also need to make an adapter for the wiring, there are a couple of ways this can be done but again, nothing too tricky.
    I'll try to find some pics/links...
    Regards,
    Rob.
  8. FactionOne
    3,272
    183
    There were some pictures to go with this but they're no longer in his webspace; I'll try to find some more. This is probably the best way to do the wiring too as you don't end up modding anything on the car's wiring...
    Regards,
    Rob.
  9. FactionOne
    3,272
    183
  10. S3 chj
    S3 chj Member
    306
    FactionOne many thanks mate realy helpfull will try and do a deal with the guy and collect them tomorrow
  11. s3ollie
    s3ollie Member
    762
    what did you guys do regarding the change position of the lower screw on the headlight? did you make a bracket?
  12. rodenal
    rodenal Active Member
    1,992
    I found that because of the way i trimmed the wing, the headlight sits in very tight anyway, so it only needs the 2 screws at the top to hold it firm.
  13. sainte986
    sainte986 Vorsprung Durch Technik
    98
