Will these fit?
braddie Feb 11, 2007
  1. braddie
    braddie Member
    35
    I want to upgrade my 17" alloys on my 03 Cabriolet to some 19 RS6 style, seen a set with an offset of 45 & stud pattern of 5 x 112, can someone tell me if these will fit or not.
    If not, anyone selling any??
  2. Randomjim
    Randomjim Active Member
    2,752
    Yup shouldn't be a problem there
  3. 1210tech
    1210tech Four Ring Fanatic Team Daytona Team V6 Audi A6 Audi Avant Owner Group S-line owners group
    696
    i would double check before you buy 'em, when i upgraded from 17" to 18" alloys the width of the wheel went from 7.5" to 8" and i bet 19" rims have a width of 8.5" so you will need a lower offset to make sure they don't rub when fitted
    the offset on my original star design 17's was ET42 but the offset on my 18's is ET35 to allow for the extra width of the alloy
  4. Randomjim
    2,752
    ET35 wheels would stick out further than ET45 by 10 mm so surely they would have more chance of rubbing.
  5. 1210tech
    696
    not unless its been lowered and its not the body work that you need to be worried about the wheel rubbing on, the extra offset is to provide clearance from the running gear on the inside of the alloy.
  6. braddie
    braddie Member
    35
    Now i'm totally confused?
    Rim width is apparently 8J, will these be ok?
  7. 1210tech
    696
    that means the alloy is 8" wide
  8. 1210tech
    696
    what alloys do you have fitted at the moment? which design?
  9. gizze
    gizze Member
    645
    They will fit fine on any B6. :)
  10. braddie
    braddie Member
    35
    Just the standard 5 star 17 alloys.
  11. braddie
    braddie Member
    35
    Great:icon_thumright:
    Will they look right though as now read up mine should be ET35:confused:
  12. Randomjim
    2,752
    You can always chuck on some 10mm spacers but they'll be fine.
  13. 1210tech
    696
    i had those on mine when i bought it. they will be 7.5" wide with an offset of ET42
  14. andyccr
    andyccr 2003 1.8T Sport Ebony Black A4 Cabriolet
    442
  15. braddie
    braddie Member
    35
    Cheers guys.
    So much knowledge on here - priceless:rockwoot:
