will these fit my car??
spencerdale May 11, 2010
  1. spencerdale
    spencerdale New Member
    25
    im in the process of doing my k03s hybrid conversion and i have been looking for 370cc injectors and found some that came off of a zetec turbo, will the fit my car? cheers dale.
  2. 1animal1
    9,978
    theres no benefit to changing the injectors with a ko3s matey....pointless exercise
  3. spencerdale
    25
    So do I not need to uprate the injectors and fuel rail is I
    running a fmic, decat exhaust ect ect and hybrid? Sorry I'm still learning, lol, cheers,
  4. spencerdale
    25
    Sorry, as I am running a fmic ect ect.........
  5. ALPINE
    3,093
    if your running a ko3 or a ko3s you need not change injectors. if you are hybrid or ko4 which are bigger then the A/F mixture needs to be balanced. I.e bigger injectors fuel pump etc. FMIC will not hurt as cooler air is cooler air. this is good in any turbo. but unless you start getting silly you will not need to change your injectors.
  6. spencerdale
    25
    right ok, so im sending my k03s to cr turbos to be converted to hybrid so its best i do the fuel rail,injectors and pump, i've been told i can use s3,tt or lcr parts, is this correct? im hoping to get between 240-260 bhp is this a good target? cheers
  7. ALPINE
    3,093
    i will know hand over to the hybrid boys to assist you further! lol
  8. 1animal1
    9,978
    yeah i think this may benefit from new injectors before you map it of course....curious why your going hybrid though? the ko3s running at 230bhp will be largely hard to drive without spinning up..... cant see why you you would want more...each to their own though
    and yes all of the above cars have interchangeable injectors ;)
