Will these fit an A3?
mhmm about the same as dealer price too so try your dealership and save on postage
Thats a good price to be fair, they are £115 from the Audi dealer since they put the prices up
Ahh right, okay thanks, I remember reading something on here a while ago about fitting them, but cant find it now! Will they be hard to fit?
The clutch and brake are just covers which pull off, then stick the new ones on top of the actual pedal
The accelerator is a bit more difficult as theres 2 little clips under the flooring which need to be got at just right with a flat head screwdriver
Ok, so does the carpet have to be lifted up?
Thanks.
I see, Ive just been to have a look, and can see the part you clip off to get to the screws. Are the electrics at the top of the pedal?
once you remove the screws you need to prise the bottom part upwards as it's slotted into the floor. When it's removed (unscrewed/ prised) then you can rotate it around to get to the electrics plug which is at the back of the pedal, you have to push down on a tab and pull at the same time
N8
503
516
