Will these alloys fit? TTS
EvolutionV Apr 29, 2010
  1. EvolutionV
    EvolutionV Member
    203
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    a4 ones are the same as them, they would fit youd require spacers, theres a set exactly the same design on for 650 buy it now but theyre off a facelift s3 these do fit, as i have a set also
  3. N8
    17,163
    718
    You will need a 10mm spacer and probably a 215/35 or 225/40
  4. EvolutionV
    EvolutionV Member
    203
    Would i need spacers on just the rears or on all 4? its ET52
    It has 245 tyres on them at the moment so i guess i have to fit a set of 215/225 stretched ones. I'm running H&R springs....
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
  6. EvolutionV
    EvolutionV Member
    203
  7. N8
    17,163
    718
    Well all 4 are 9J and ET52, so then you'll need spacers on all 4, and yes 215/225 tyres, as I've stated!!!
  8. gingers3
    gingers3 Active Member
    678
    119
    43
    you would be better getting s3 oem rims 7.5 j , same style
  9. N8
    17,163
    718
    Unless he's goin for poke and wants some stretch Ginge?
  10. PH1L
    PH1L Gievf Buckets
    3,851
    40
    true and that would be sexy as well!
