will the problems ever stop????????????????????
bansheeboyo Apr 28, 2010
  1. bansheeboyo
    bansheeboyo Member
    201
    well guys more bad news sigh
    my rear brake calipers are seized
    what modles rear brakes will fit on my a3tqs ?????
    i tryed the caliper rewind tool the day nothing didnt budge so peeved of its nay real.this car realy dosnt want me to save for a evo :crying:
    cheers scott
  2. jonny87
    jonny87 Active Member
    1,094
    why not remove them and rebuild them with new seals?
    if not theres plenty of 2nd hand calipers for a3s on ebay, ive been looking the last few days
  3. Welly
    Welly VX220 SC Driver :)
    10,696
    128
    Just a quick question (not doubting your abilities), but did you take the cap off the brake fluid reservoir?
    Seems odd for BOTH rear calis to seize up at the same time.
  4. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    Is this a common fault on all VAG cars? I know the mk2 and mk3 golfs were prone to this due to there limited use.
  5. sportstractor
    sportstractor Chugger
    2,709
    sounds like you need to man up and give it more welly! Try pushing the pistons in a bit with a G-Clamp before winding
  6. A3 XME
    A3 XME Member
    39
    lol, problems, i bought my audi 3 1.6 sport on the 15th of this month (april). drove it 180 miles and the gearbox blew (luckily on the back of my house), anyways, bought a new gearbox and fittred it, then there was missing, so i replaced the ht leads and plugs, fine, now i had a leak in rad, fixed with rad weld, then another, fixed with rad sealent. now after doing 600 miles with this gearbox, reverse went dus to a hole blowin in the gearbox lol, luckily have warranty on gearbox so get another at weekend but seems to be problems lurchin round the corner for a lot of audi owners atm.
  7. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    I think its the rallyart mudflaps that caused it.
  8. Welly
    10,696
    128
    :lmfao:
  9. bansheeboyo
    bansheeboyo Member
    201
    :lmfao: good one minty
  10. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    I recently rebuilt my rear calipers, with a kit. Took about 30 mins per caliper to fit the new seals. The only thing I found when trying to rebuild the calipers is that inorder to wind the pistons back in fully you need to pump the pistons fully out first. If you're not rebuilding them, pump the pistons out with the handbrake lever with the calipers off then once out try winding back in.
  11. bansheeboyo
    bansheeboyo Member
    201
    eh no welly ,i did not ,damn my inexperience....i thought loosening the bleed nipples would do
  12. bansheeboyo
    bansheeboyo Member
    201
    will ones from a non quattro fit ??
    or mk4 golf
