will the clutch kit be suitable
deac666 Oct 22, 2013
  1. deac666
    deac666 Member
    45
    Hi all will this clutch kit be ok for my 2002 a3 tqs ebay item number 110951762121
    Cheers jon
  2. aragorn
    18,490
    855
    It says "6 speed models" so i'd imagine no.
    I wasnt aware they did 6 speed cars with those engines though.
  3. deac666
    deac666 Member
    45
    my engine code is ary ive contacted the seller and they say it fits. just want to make sure.
    seems like a good price and its only going in a daily driver.
    Cheers jon
  4. <tuffty/>
    21,578
    4,049
    If its an 02M five speed box then it should fit...
  5. deac666
    deac666 Member
    45
    my car uses a six speed box. so I take it that this will not fit.
    any links to what would work been told s3 clutch a fly wheels work. would just like someone to help make sure I get the right one as I want to keep the cost down when it goes to the garage. any help/advise greatly received.
    Cheers jon
  6. <tuffty/>
    21,578
    4,049
    6-speed is 02M too... they did a five speed version on the quattros fitted to some TT 180's and A3 TQS... anything quattro got an 02M box
  7. deac666
    deac666 Member
    45
    ok I see any Quattro 02m box but some were 5 speed and some were 6 speed. if it for the 6 speed then it will fit??
    Cheers jon
  8. <tuffty/>
    21,578
    4,049
    Have you tried sensing the seller a msg asking the question quoting your model/engine code? worth doing as if you buy it and there is a problem you may have no come back as its listed for a differnt car...
  9. deac666
    deac666 Member
    45
    have done this tuffty and seller says that if there is a problem then they will take a return at there cost. so will probably go for it. thanks for all help.
    cheers jon
