Will S4 Xenons fit into a standard A4?
VTEC_Killer Apr 15, 2009
  1. VTEC_Killer
    VTEC_Killer Member
    92
    Will a set of S4 xenon headlight units (from a 2004 model B6) fit straight into standard A4 B6 2004?
    Correct me if I'm wrong; the socket is plug & play and will fit like the current unit and won't need any special plug adaptors?
    Part number for S4 unit is 8H0941004BB! My car is 1.9 TDI
    Thanks in advance
    :icon_thumright:
  2. davidkoulakis
    davidkoulakis Member
    66
    dont xenons require headlamp washers by law (MOT etc)
  3. LeeT
    LeeT Member
    429
    ive not heard of that before. My old BMW had Xenons but no washer jets?
  4. VTEC_Killer
    VTEC_Killer Member
    92
    They do but this is a close as an original 'retro fit'
    Obviously the lights won't auto level and neither will there be washers (not bothered about that) just need to know whether the xenon unit will straight on!
  5. docurley
    4,070
    85
    Yes but you will need a adapter lead to allow them to work.
  6. VTEC_Killer
    VTEC_Killer Member
    92
    Expensive and where can I buy this from?
  7. no_idea
    no_idea Member
    170
    Hi Vtec
    Just had a quick look in etka, I think you will find they are off an S4 cab. I don't think they will fit a saloon or avant. I am sure someone will confirm this though.
  8. docurley
    4,070
    85
  9. docurley
    4,070
    85
    Cab lights will not fit the Saloon or Avant
  10. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    It's all here Official DOT Link - and Yes you are correct.
    After two MOT's with retrofit Xenon HID's, (no washers and only 0/1/2/3 manual leveling) - All passed 100% - No problems.
    I do carry around the H7 Halogen bulbs and can revert back at the roadside if I was ever stopped!
    Spoken to a couple of policeman and they are not aware of any offences being committed. Unless you've really gone OTT on creating a Chav Audi then the odds are in your favour of not getting stopped - probably not the best odds if your in your Chavy 106, Corsa, or Saxo, etc. retro-fitted with Xenons.
    Maybe MOT tests could get stricter and then we may have top revert to a compliant HID system?
    Not going to lose any sleep if my headlights are in correct alignment with Xenons.
  11. J7USS
    J7USS Shuddup Foooool!!
    3,737
    76
    I was even considering buying these just so I dont have to do the Joey Mod on mine. £199 BIN is a good price if you can get them to work, little steep on the postage though IMO
    The guy who selling them states they are off a saloon but the part numbers are coming up Cab...:uhm:
  12. Woorlord
    951
    Definitely off a Cabriolet and checking ETKA can't see that any of the parts are salvageable to remount on your existing light assembly. Ballasts are different to those used on the B6 non-Cabs.
  13. VTEC_Killer
    VTEC_Killer Member
    92
    Thanks guys - much appreciated :thumbsup::respekt:
    So, just to confirm - the S4 saloon or Avant will fit but only the Cab won't - correct?
    :salute:
  14. Woorlord
    951
    Yep - That's it!
  15. golf
    golf ***** rent boy VCDS Map User
    1,556
    I had a set of these last year from a saloon. As far as I know they are a direct swap for the original halogen lights. The S4 bulbs are type DS1 though and not DS2. DS1 are bloody expensive and much harder to find.
