will H & R 50mm be enough
tdi-man Aug 25, 2011
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    Heres my car on s-line spings will H & R 50mm spings be enough is the question ?
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    enough for.....?
    Will the stroke of the standard dampers still work effectively with a 50mm drop?
    I don't think you'd want to drop futher TBH, but if you look at this thread it spelss out the ride height differences between all the models givign an indication of how far you may or may not want to go... LINKY
  3. tdi-man
    1,783
    64
    all my dampers are about 12 months old.
  4. warren_S5
    7,210
    2,486
    What I mean is the damper stroke (maximum extension to maximum compression of damper piston) will have an effective operating limit to work within (so many centimeteres), and if you put too short a lowering spring on it, the damper will not function effectively which will significantly affect ride comfort and but more importantly handling.
    Speak with Damian at DPM who can recommend how far you can drop without affecting the dampers performance to do it's job.
  5. GNJ_Motorsport
    GNJ_Motorsport Site Sponsor Site Sponsor
    660
    188
    43
    It will be ok I think. A full kit would be better and the ride might be quite harsh but it all depends on what you want & how much you want to spend.
  6. warren_S5
    7,210
    2,486
    Actually, a quick plunder through the archives find this has come up before and this was Damian's reponse:
    LINK
  7. Ash187
    7,478
    735
  8. munchkincoupe
    munchkincoupe Member
    948
    19
    tdi man - I've had the same set up as you are looking at fitted for the last 4 months - low mileage S-line dampers with 50mm H&R springs and I think it now looks and rides perfectly
  9. tdi-man
    1,783
    64
    can you put up pic please ?
  10. munchkincoupe
    948
    19
  11. munchkincoupe
    948
    19
    That's the closest pic I've got to side on - will get one later in the week
  12. Chappy
    Chappy Call me Dan! Audi A5
    471
    25
    Looks good that, how much are the springs?
  13. tdi-man
    1,783
    64
    looks just about right.
    thats me getting H&R then
  14. munchkincoupe
    948
    19
    I'll find the receipt but I got them supplied/fitted by AwesomeGTI - check their website
  15. tdi-man
    1,783
    64
    springs are £200
  16. munchkincoupe
    948
    19
    £416 for supply/fit of springs, supply/fit new top mounts (worth doing whilst there as new set up will stress them more) and carry out geometry set up - 2 hours labour
  17. DPM
    DPM Site Sponsor Site Sponsor
    4,987
    200
  18. shady-ninja
    shady-ninja Active Member
    999
    53
    Nice car mate.
    is this with stsndard shocks??
  19. munchkincoupe
    948
    19
    Standard S-line dampers (shocks) with 50mm H&R springs and A6 Quattro 18" wheels
  20. shady-ninja
    999
    53
    do you think the same spring will work on an A3 aportback sport model.
    mine is slightly lowered.
  21. munchkincoupe
    948
    19
    Mine is a sport model originally but the s-line dampers are a better match for the lower springs. You may find that the sport dampers will die quickly with these springs
  22. Ads
    Ads License to drive
    8,230
    608
    As far as I know, the Sport and S-line dampers are the same though. Mine is a Sport and I have checked my part numbers against two sets of s-lines and they were identical. Also two people I've spoken to have had it confirmed, one by Audi and one by a VAG parts dealer.
    But I'm genuinely interested to know why you think the Sport and S-line dampers are different?
    Do you know the part numbers of your s-line dampers?
  23. munchkincoupe
    948
    19
    I spoke to Dave at Stoke Audi. He checked the part numbers and told me they were different
  24. Ads
    8,230
    608
    Do you know what the part numbers of both are?
  25. munchkincoupe
    948
    19
    I don't sorry. Might be worth messaging Dave in the Stoke Audi section
