Will ET35 BBS wheels fit an S3?
Defratos Jan 6, 2007
  1. Defratos
    Defratos You’re Dethpicable!!
    2,232
    Just wondering if 18x8.5 +35mm offset will fit me 2002 S3?
  2. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
  3. Ess_Three
    Ess_Three Active Member
    5,383
    Yup, they'll fit...
    But, beware of what size spacers you run at the front.
    If you NEED to run spacers to clear the brakes for example, and run a lot lower than standard, you may be close to rubbing, or rubbing with 8.5" wide ET35 wheels and 10mm spacers.
    I reckon you should just be Ok...but 15/16mm spacers will most likely cause rubbing.
  4. Defratos
    2,232
    I c, thanks for the help I think I'm gonna go with that
  5. simch
    simch Active Member
    2,028
    8.5 by 18 ET30 will fit, (BBS CHs). So 35's will be fine, wihtout spacers.
  6. Defratos
    2,232
    anyone looking for 20mm rear spacers? lol
  7. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    With an 8.5" et35 you'll be getting close to the strut on the inside.
  8. Defratos
    2,232
    Ok, what's the strut on the inside? I wanna know how these wheels will sit in the archs and how it'll change handeling. Do u know if it'll damage the strut on the inside? only reason I'm after these wheels is because I've seen them on another S3, but can't get hold of the exact rim spec.
  9. ChriS3
    2,239
    27
    It's the suspension strut you'll be gettin close to. Have a look at the link FactionOne posted, that'll show you how the wheel sits in the arch. As for a change in handling, thats also dependant on wheel weight, offset, width, size, and so on.
