Will Boxster BRAKE CALIPERS fit the a4
billybravo Nov 8, 2007
  1. billybravo
    billybravo Active Member
    1,045
    FROM 1999 2.5 BOXSTER 4 pots how do i get these to fit the a4 is it a case of just getting new carriers??
    thanks
    craig
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,775
    33
    Do you know if they are radial mount?
  3. billybravo
    1,045
    no
  4. dappadan786
    dappadan786 Member
    457
    if its the standard 4 pot boxster calipers all you need is the carriers and your away! you should be able to then use the 312mm rotors i believe!
    i looked in to this a few months, made my head hurt lol! in the end i just thought sod it and ordered the ECS tuning stage 2v2!
    hope that helps mate.
  5. billybravo
    1,045
    cheers dude :) do you know where i can get the carriers
  6. dappadan786
    dappadan786 Member
    457
    vag parts do em i think or its going to be the good old US! not cheap though can cost up to £100+ for the pair once u take in to consideration the cost of pads, discs, brake lines and calipers you could hit £500 before you know it!
  7. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    get some made up.
    there is a set on eBay and they kindly give all dimonesions needed, any engineer could do it for £50 tops!
  8. billybravo
    1,045
    jcb pm me the link please
  9. waveform2
    waveform2 * J e d i *
    435
    yeah 90 odd+vat from VAG parts but look good quality.
