Will avant 1.8t springs fit my 1.8 saloon?
9 below zero Mar 13, 2010
  1. 9 below zero
    9 below zero Member
    76
    I've got a 96 1.8 manuel petrol and i bought 40mm lowering springs. The back of the car sits lower than the front so i need to drop it 60mm-40mm. I've been offered some 60mm springs off a 99 1.8t avant, will these fit?
  2. Broken Byzan
    13,237
    466
    Yep, may not drop the back as much due to the avant springs having a higher spring rate on the rear, front are fine assuming they both from manual 1.8s with aircon
  3. 9 below zero
    9 below zero Member
    76
    yes they are both from manuals but the avant had air con and mine doesn't. Will this make a visible difference?
  4. aragorn
    18,609
    871
    will mean it lowers less.
    Its probably why your current springs arent even anyway though, they'll be designed for a car with aircon.
