Will a set of alloys with an ET of 35 Stick out to much on my A4 S line?
fozworth Sep 20, 2010
  1. fozworth
    fozworth Member
    85
    Ive ordered some replica S5 twin spoke alloys with an et of 35 but i think i should have ordered et42 am i correct? my current RS6 FIVE SPOKE stock alloys are pretty flush on the front arches although the rears are set in a bit .I think the rs6's are et42?
    can anyone advise.
    cheers jamie
  2. Stepho
    Stepho Member
    444
    These will be fine Jamie. Couple of the guys on here are running ET35 19" wheels with no probs. I went with 8.5J ET45 19's and had to fit a 4mm shim on the front as it was a little to close on the suspension arm.
  3. fozworth
    fozworth Member
    85
    so the fronts wont stick out to far? these are 18's by the way
  4. Stepho
    Stepho Member
    444
    The clearance from stut housing to the inside of the wheel will be 8mm MORE
    The outside edge of the wheel will EXTEND an extra 8mm
  5. fozworth
    fozworth Member
    85
    So will 8mm be to much on the front as they look pretty far out on stock et43 rs6's
  6. ultramodz
    ultramodz 06 A4 2.0T FSi S-Line SE
    515
    I'm running 8.5x19 ET25 (225/35/19) on the front & it's just shy of being flush with the wheel arch. ET35 will be fine.
    Yes, ET25 does rub, but only occasionally!
  7. fozworth
    fozworth Member
    85
    Gone for et42 instead as i like the fronts how they are but will get some spacers for the rear asap
  8. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    ET35 on my B6 1.8t S-line lowered on Eibach pro-street.
