Will 18x9s fit?
purpleturtle May 30, 2013
  1. purpleturtle
    purpleturtle New Member
    Hello, I'm new to the forum and the world of B5s but just a quick question.....
    Will 18x9 ET35 front & rear fit on a B5 1.8T 2000 Avant with coilovers? I'm concerned about them needing spacers for clearance but would this then make them protrude from the arches?
    Ideally, I don't want to have to do arch work but just wondered if anyone was running 18x9 ET35s all round and if so, how is this achieved?
    I'm basically looking to purchase these Merc rims.
  2. scr8pdo
    scr8pdo Member
    199
    I think they will as my B5 is shod with 235/35/19s and coilovers, they JUST about clear, I couldnt fit the rims with 255s mind (they would foul) sorry I not sure of the offset but IIRC these are RS4 rims????
  3. purpleturtle
    Ok sure. I was probably going to run 215/40/18.
    So what's the width of your 19"s?
  4. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    so you going to buy 18" or 19" wheels
    fyi i have audi rs4 alloys on mine with ap coilovers running 225/45/18 tyres (audi a4 b5 quattro) and there 18" 8.5j et35 ,
    so .5j isnt much and to be fair at most your need a 5mm spacer.
  5. scr8pdo
    scr8pdo Member
    199
    I will have to have a look as I dont know TBH, I have a wheel off at the mo for a puncture so I will have a look and get back, they do sit very close at both the front and rear, I cant squeeze my fingers between the tyre and the suspension, but it does clear JUST as I say there would be no chance of fitting 255s (I did try)
  6. boost-addict
    1,000
    39
    255's? think you lot are geting confused, one of you are talking about 18" wheels and the other is talking about 19" wheels
  7. purpleturtle
    Sorry, I meant 18" as per thread title. Getting late in the working day :sm4:
  8. purpleturtle
    Actually this thread has pretty much answered all my q's, cheers all
  9. aragorn
    18,137
    765
    essentially no, they wont fit.
    You might be able to bolt them on, and have them stupidly poking out the arches, but thats not really the same as them fitting is it?
    215/40 is also completely the wrong size tyre, both for the car and more importantly for the rims.
    9" wide wheels should be on something like 255/35R18's
  10. scr8pdo
    scr8pdo Member
    199
    No I realised he was talking 18", I was saying that the 18s would probly fit as I have 19s on mine fitted with 235/35s but I tried to fit 255/35s and they fouled the suspension on the same rims :)
  11. s200rey
    s200rey New Member
    15
    Howdy, I have a B5 Avant, a 2.5 TDi Quattro, and run 9J (ET52) 'new style' Genuine Audi TT alloys, at the rear 235 - 40's and at the front 225 - 40's. To get them to sit nicely I have 15mm Hubcentric Spacers & long nuts, on all four corners, otherwise due to the high offset they would fowl on the upper control arms etc. I now have a couple of mm clearance, which hasn't been a problem, no rubbing or scrubbing at all, even with the kids in and a boot full of shopping, so happy days! I'm pretty sure with a lower offset you wouldn't need such wide spacers, but I love these wheels and there quite rare on anything but a TT so just had to 'make them' fit lol...
    Here's my car as it is now (desperate for a good clean, lol) but sits nicely, all be it on standard shocks & springs.
  12. purpleturtle
    Like I said, I don't want them to protrude from the arches, hence the question in the first place. I know they will bolt on, that really wan't what I was asking.
    Re tyre sizes - some like stretch, some hate, it's one of those things.
    Great intro the forum though, many thanks
  13. purpleturtle
    :yes: Great stuff, that's sitting pretty
  14. Chriscooke
    Chriscooke Clueless!
    500
    24
    It all depends on the look you are going for really. I don't think stretched tyres and wheel poke really suits the b5 but it could be done to help fit a certain set of rims. A lot of the vw boys do it after all.
  15. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    If you're running 215/40 on a 9j rim, it will cause the tyre to stretch, which I would guess cause rolling circumference of the tyre to be different from if the tyre was fitted go a 7j and no stretch caused?
    How would this effect the Speedo reading?
  16. Chriscooke
    500
    24
    Having your speedo out can be annoying but the small change in radius from stretching the tyres wouldn't change it drematically. If you check it against a sat nav you'll know where you stand also. You get used to it quickly also :)
  17. ScottD3
    15,161
    1,121
    I did this today and mine is bang on. lol
    75mph on the speedo is 74 on the satnav.........ok not bang on but as good as.
  18. s200rey
    s200rey New Member
    15
    Tested mine today, against sat nav, and speedo to sat nav was; 70 - 71, 80 - 81, 90 - 92, so cant grumble...
  19. boost-addict
    1,000
    39
    On a private road right? Or kmph? ;)
  20. Chriscooke
    500
    24
    My a4 is also spot on. The Nissan I have with a different from standard wheel package under reads by 5mph. I don't mind either as with the Nissan it means I'm that little bit less likely to be caught speeding :)
