Wifi obd adapter?
Powelly Jan 14, 2013
  1. Powelly
    Powelly Member
    85
    Seen the Bluetooth ones, thinking of getting one of these to try with my iPhone app by xtool ''IoBd2'' really good interface and functions etc so wanna give it a go on my A3 and Mondeo, just wondering if anyone has tried this one or similar!
    Cheers in advance!
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
    Yup, worked well for basic fault codes and logging.
    Used the android app not the iPhone one.
  3. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    I have one with iPhone app. Works well gauge function can be a little laggy though.
  4. Powelly
    Powelly Member
    85
    Cheers chaps! Got a Android tablet Scott, What app do you use?
  5. <tuffty/>
    21,950
    4,227
    Torque and the bluetooth adaptor work well... but as said it is laggy...
    Screenshot from my Galaxy S3
  6. Powelly
    Powelly Member
    85
    Much point in going for a Wifi one? Any benefits over the Elm327 Bluetooth ones?
  7. <tuffty/>
    21,950
    4,227
    Bluetooth is much cheaper and as laggy as the wifi one...
  8. Powelly
    Powelly Member
    85
    Righto cheers Paul, May as well just get a Bluetooth one then, There's loads on Ebay, Any of them fine as long as they are Elm327?
  9. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,304
    374
  10. ScottD3
    15,166
    1,126
    Looks good but I wonder how much it will be.
  11. Scullies
    Scullies Well-Known Member
    1,543
    658
    oooooooooooo :happy:
    I tried the wifi and iphone/ipad with REV and DashCommand route - gave up in the end. Will try again when the car is running. There is also a bluetooth app on cydia for jail broken devices that supposed to be a get around for the limits of iOS.
    Heard the torque android app is much easier.
  12. slvrb5s4
    slvrb5s4 New Member
    I got the Bluetooth one from eBay for 20$ and it works perfectly. I've had it for one year now, the bad thing is everybody calls me when they have a cel on now.
  13. JudderMan
    JudderMan Well-Known Member
    1,032
    174
    When you guys say laggy do you mean in real time or the results are ****? Does it log the information to look at later/safely not while you're driving? Really don't want to spend £225 on a Liquid Gauge when I have a redundant iPhone 3GS in my drawer. Is it just a case of mounting the phone, adding the OBD connector and an app - what app is best, Dash Command as above or others?
  14. LiveWire
    LiveWire S3X
    329
    I just wish the ELM 327 and Torque app would show Oil Temp :O(
  15. <tuffty/>
    21,950
    4,227
    Realtime is a little laggy... tbh I use Torque more than my liquid at the moment as for idle curiosity as to whats going on its perfect...
    I have not used it for logging but tbh would only ever use VCDS or ME7Logger
    Can't speak for the iphone though as I think the app for that is called Revs and uses the more expensive wifi dongle...
  16. Goubo1
    Goubo1 Well-Known Member
    958
    298
    Wouldn't mind getting this for my iPhone or ipad,any help for what app to use or dongle to buy would be great
  17. <tuffty/>
    21,950
    4,227
    Oil temp is not an ECU function... its the instruments module that handles that... I suspect Torque doesn't talk to any module other than the ECU and even then its not perfect... I am still trying to get the EGT PID working and it doesn't see alot of VAG extended OBDII codes on a scan
  18. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,292
    638
    These devices are OBDII compliant, so you only get the emission related info required by law. Still good to have, but will never have VCDS level of detail. If you have the MIL lamp illuminated, these will tell you why as it is emissions related in order for MIL to trigger.
    Also, Wifi is needed for iOS as Apple doesn't support the serial bluetooth protocol.
    Rick
  19. WorkInProgress
    WorkInProgress Member
    253
    Does Torque work with AGU engines yet? I had it previously and it wasn't compatible, dunno if it's changed yet
  20. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Hmm v interesting as i was looking at these the other day too, as of course VCDS is great but i would like something that i can use on the fly as such and dont wanna go spending out on a liquid gauge.
    Can someone who has the iphone version one working post up a link to the OBD adapter on ebay or similar please also what were the names of the apps to use on the iphone?
  21. A3 T
    A3 T Lord Of The Rings
    1,077
    15
    Have a look at the thread i just made ;)
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/179362-bluetooth-obd-setup.html
