wierd wine noise from under the bonnet
nervus Sep 17, 2004
  1. nervus
    nervus Well-Known Member
    1,370
    121
    This morning i found a wierd wining noise coming from under the bonnet which got worse when i steered. I thought it must be the power steering or something but then steam started coming from the front drivers wheel arch.
    Anyone know what the problem could be as the coolent levels were fine???
  2. nervus
    1,370
    121
    Ok whats the serpentine belt? will it cure when its dried off?
    Both my cars are now in the garage /ubbthreads/images/graemlins/mad.gif. Everyone at work thought it was hilarious till i turned up this morning in my dads 360 modena - that wiped the smiles /ubbthreads/images/graemlins/cool.gif
    Audi didnt have a C Car so i got dropped at my dads.
  3. Add7
    Add7 Member
    310
    track rod arm?
    When mine went it made a really annoying rubbing sort of noise?
    Just a thought.
  4. S3_MCD
    S3_MCD Member
    389
    Power steering pump, another one of those things that i've had replaced under w'tee.
  5. Agree with steering pump answer , having mine replaced on Tuesday under warranty , has been leaking fluid and started making the same sort of noise you describe.
    Then write my letter to Audi UK asking for an extension on my warranty due the things wrong with my Approved Audi which I dont think had a 20 point check let alone a 100+ point check !
  6. nervus
    1,370
    121
    It was the power steering pump!
