wideband conversion thread
jcb Feb 8, 2010
  1. jcb
    jcb Active Member VCDS Map User
    4,132
    13
  2. aragorn
    18,490
    855
    i dont get it?
    You surely cant just add some new pins onto the ECU and hook up a wideband...
  3. aragorn
    18,490
    855
    Ok reading a bit more it seems hes swapping the engine ECU out for one from a wideband equipped car.
    Bit tricky on a B5 though as you'd need to be on DBW, and only the immo3 equipped cars have the canbus guff that the later ECU's rely on.
    You could convert to electronic pedal, but the immo would be tricky, and you'd need to find an entire engine harness from a suitable M7.5 car (B6 perhaps?) along with the throttle body etc.
