Why would throttle not work ?
xxxxSMITHYxxxx Aug 28, 2013
  1. xxxxSMITHYxxxx
    xxxxSMITHYxxxx Member
    37
    Guys I have had a few problems but some times when I start the car the throttle won't work, but after I turn off the on back on again seems to work ok but uses loads of fuel pleas help
  2. badger5
    9,398
    1,943
    what car?> any fault codes?
    got vcds?
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,814
    193
    Stabbing in the dark at a landa/egr wiring issue, possibly chaffing wires, throttle pedal is on same loom. Scan it with vcds. We cant read your cars mind!
  4. <tuffty/>
    20,881
    3,701
    I think his car is an AGU...
    Personally I think its an airleak thats causing the issues and the OP is confusing the symptoms...
    A scan for fault codes and some elaboration on the symptoms would be a start :)
  5. <tuffty/>
    20,881
    3,701
    Ok... had a quick look at the OP's other posts and it appears he has an A3 quattro... guessing its a 1.8t and will be DBW...
    Still think its an airleak...
  6. badger5
    9,398
    1,943
    another of the not helping folks help themselves by not posting the actual car or spec...........
  7. xxxxSMITHYxxxx
    37
    Hay guys sorry been at work yea it is a W plate 1.8t Quattro, could coil pack problems do this ?
  8. badger5
    9,398
    1,943
    low battery will cause throttle to not want to work...
    check your fuses also...
    earths..
    and if you have access to someone with vcds, that will help diagnose things
  9. xxxxSMITHYxxxx
    37
    Sorry guys at the risk of sounding like a real noob, what is vcds
  10. badger5
    9,398
    1,943
  11. <tuffty/>
    20,881
    3,701
