Why Would It Do This?
A3 T Mar 9, 2014
  1. A3 T
    A3 T Lord Of The Rings
    1,077
    15
    For some reason while driving along at a steady speed (not fast) I hear the car dump the boost (not that there should be much boost to dump at this speed).
    Also sometimes while accelerating from a stop I hear the turbo start to spool up and then the boost gets dumpped and the turbo just spools up again.
    Any ideas what this could be (n75 maybe) ?
  2. A3 T
    1,077
    15
    Anyone ?
  3. cammage08
    cammage08 Member
    171
    10
    Have you bypassed the n249? This little monkey will dump boost lile this if something is wrong...
  4. <tuffty/>
    21,879
    4,202
    Sounds like its going into limp mode... you need to scan for fault codes in the first instance and post them up
  5. JudderMan
    JudderMan Well-Known Member
    1,026
    172
    I found a small hole in my TIP that is causing something similar. Friggin £100 worth of pipe that has been rubbing on a jubilee clip which I hadn't noticed. Gutted. (N249 delete too btw).
  6. david7m
    david7m Active Member
    551
    44
    Silicon plus a few wraps of black duct tape? Cheap bodge until a used one comes up :p
    Dave
    JudderMan likes this.
  7. JudderMan
    1,026
    172
    Well....I am from Newcastle....pikey bodge jobs are my forte ;)
    s3dave likes this.
  8. A3 T
    1,077
    15
    Thanks for all the replies ;-)
    I've already done the n249 bypass (as shown in my sig) and I'm not getting any fault codes.
    Its also not going in to limp mode as it spools straight back up.
    Let me try and explain it a bit better..
    If you was to watch the boost gauge then at idle it would sit at -20, as soon as I start to pull away (smoothly not putting my foot down) the turbo quickly spools up and the boost gauge gets to about 0 then the boost dumps and the turbo spools up as it should at a normal pace.
    Could this be the n75 causing boost surge?
  9. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,927
    760
    I've had exactly the same problem for a long long time, a few people have mentioned having the same thing on VAG talk as well. No leaks, had it smoke tested a few times, no codes, took a trip up to bills and got it remapped and everything was fine when he scanned and smoked it, still happens, think it's always happened since i've owned the car
  10. JudderMan
    1,026
    172
    Could it be your Bailey dump valve? Can you try an OEM one to check? Sorry I can't help with the N75 thing I still don't fully understand what it does/how it works.
  11. A3 T
    1,077
    15
    I've tried the standard valve but it didn't make any difference (I've got a forge one on there now).
    Another thing I've noticed that's probably not related is that sometimes if I put my foot down it feels like its lacking power, almost like I've got it in the wrong gear.
