Why is the 2.0tdi cabriolet single cam 8v
RMH1A4cab Sep 12, 2012
  1. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    549
    19
    I've known this for a while, it doesn't bother me I just wondered why, I also want to clean the egr valve but it's completely different to all the write ups on the Web. :)
  2. hades-
    9,480
    646
    same as why the 18T has got 5 gears
  3. Gazthesparky
    Gazthesparky Member VCDS Map User
    217
    RHM1Cab
    I cleaned the egr valve on mine
    Quite an easy job it requires a Allen key and it's located to the left of the oil cap
    It slides in sidways to the exhaust manifold you undo 3 Allen key bolts and it slides out unplug the connector and then clean the valve with carb cleaner
    Once clean I just re installed it
    I never found any write ups on the net for this type of egr valve
    I checked elsawin to confirm and that is the egr valve
    Here's some before and after photos
    ImageUploadedByTapatalk1347482192.180434.jpg ImageUploadedByTapatalk1347482219.740191.jpg ImageUploadedByTapatalk1347482254.284349.jpg
  4. RMH1A4cab
    549
    19
    :thumbup: did it make any difference.
    Strange the way they differ from model to model even with the same engine.
    Mate of mine has just picked up a porsche boxster as a weekend toy and it's only 5 speed.
  5. Gazthesparky
    217
    It didn't seem to make much difference if I'm honest, but it's good to know its clean.
    There is also another valve nearer the windscreen the one which has a squarish box on which pokes through the plastic engine cover. I tried to take it off to clean but i was unable to get at the screw to undo it. I'm not sure exactly what it is but Im guessing it will be covered in carbon so next time Ive got some spare time I'm going to investigate :)
    RMH1A4cab likes this.
