Why is my engine cold to touch after a run?
S3 Nattie Nov 26, 2009
  1. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    The stat has to be put in a certain way around. I checked this in the haynes book when I replaced mine earlier on today.
    Its just off the vertical as you look at it if that makes sense.
    My money is on air in the system.
    T
  2. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    I will give the first suggestion ago then go from their. I have blead a few systems before and it so easy if there is a bleed screw.
    It a strange problem this as the car drives fine although a few psi down on boost. The temp gauge is alway on 90 an the CC is near enough the same and the coolant level is the same but the engine is still touchable after a quick blast.
    Will give it ago in the morning and will report back.
  3. NHN
    29,327
    1,708
    Yeah but if the temp sensor/s are the warm side of the system then they would show this temp fella.
  4. pauldazzle
    pauldazzle Well-Known Member
    1,132
    81
    Absolutely, the coolant temp sensor is on the hot side. So in all likelyhood your temp gauge would read mormally.
    Nathan if you need another pair of hands to help with this pm me & we'll meet up in Cardiff somwhere.
  5. S3 Nattie
    1,599
    Ye are right. The top coolant hose ( hot one in my case ) goes straight to the coolant temp sensor.
    Thanks for the offer Paul. I had a quick go earlier while it stop raining for a whole 10 min. Had the heater and fans on max with the expansion cap off but the engine wouldn't get up to 90 degrees. Going to give it another go after uni tomorrow depending on the weather. If im still not getting there I will take you up on your offer Paul.
  6. S3 Nattie
    1,599
    OK well had a little go at trying to get a air lock out.
    Started the car with the cap off and heaters on max. Keep squeezing the bottom hose for a good half hour and there were tiny little bubbles come up every time I squeezed the hose, not sure if the bubbles were because I keep squeezing the hose as they were tiny.
    The car gradually got up to temp. The water wasn't bubbling or rising when I increased the rpm. Not sure what to do next.
  7. pauldazzle
    1,132
    81
    You need to squeeze the top hose too.
  8. S3 Nattie
    1,599
    Ye I was squeezing the top hose too, it wasnt making no difference to the coolant in the tank though.
    I was thinking earlier, shouldn't the thermostat hose by colder than any other hose within the engine as it contains coolant from the radiator. The coolant from the engine is going through the top radiator hose and travelling down the radiator where it should be getting cooled down in the process, then back through the thermostat. Correct me if im wrong anyone.
  9. pauldazzle
    1,132
    81
    No the bottom hose should get hot too, when the thermostat has opened.
  10. pauldazzle
    1,132
    81
    Did you notice if there was any flow back into the expansion tank?
  11. S3 Nattie
    1,599
    OK. I thought as the radiator is cooling down the coolant it would be cooler than the top hose as this is coolant that as been circulating around the engine.
    Since trying to get the air locks out this morning the car seems to be emitting more white smoking than usually, wouldn't say its condensation either. Do you think I may have made more air locks lol. Why dont we have a nice and easy bleed screw.
  12. Dani_B19
    9,159
    359
    Mate just take it to a garage and let someone do it.
  13. NHN
    29,327
    1,708
    TBH I would empty the system as I already advised, then check the stat installation, then refill slowly let it stand for 2 hours then try again, failing that do as Dan said cause you're getting nowhere fast.
  14. S3 Nattie
    1,599
    Ye thats what im going to do. Empty the system and refill, if this doesnt fix the problem il take it to my specialist.
    Quick question, where to is the drain screw on the system and how much coolant/G12 should it take to refill.
    Thanks Nathan
  15. S3 Nattie
    1,599
    Ok, for the first time im glad I burnt my hand lol. Got the bottom hose to get hot, hopefully it stays like it. I will keep checking it over the next few weeks.
    If anyone else is having the same problem, cold thermostat hose, all you have to do is let the engine warm with the expansion cap off till the fans kick in which should mean you are now getting hot coolant circulating around the engine with no air locks.
  16. pauldazzle
    1,132
    81
    Glad you got it sorted:icon_thumright:
  17. NHN
    29,327
    1,708
    So you're telling me you didnt remove the coolant at all just left cap of, guess could of relieved some pressure huh, oh well one to remember & must have been air lock then
  18. S3KO4
    S3KO4 Member
    850
    is the boost back on then?
  19. Westy
    Westy Well-Known Member
    17,443
    1,103
    If you haven't done a full flush then you may find that you have only temporarily cleared the air lock by removing the header tank cap. Keep a beady eye on it!
  20. S3 Nattie
    1,599
    Ye going to keep an eye on it. I rang my specialist and they say thats what they do when they do a stat or head gasket.
    I may change the coolant sensor soon just to rule it out. My gauge aint spiking as high lately and its not as smooth when on boost.
