why is my DIS doing what its doing
Tom_B Oct 3, 2013
  1. Tom_B
    Tom_B Member
    292
    20
    On my 2.5 v6 the dis just looked a bit worn out and missed pixels from the top down in a kind of fadey outey sort of way. My Lad's 1.8T did the same thing.
    However - on dearly beloved SE the DIS seems to have horizontal lines that dont light up and then soemtimes vertical lines that dont light up. Bizarrely yesterday when I chugged up and down the rainy M1 to Milton Keynes it all lit up perfectly.
    What causes the DIS to fail and what could be happening on mine that the faiiure is inconsistent?
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    Its a known issue on most dis's from the 90s to around 2001 I think.
    The contacts break up in the ribbon cable from the PCB to the screen it self.
    The only way to fix it is to replace the screen.
    Buy one off ebay (Not the chinese cheap version) for about £50, unsolder the old and solder the new in. Done. :)
    You need a thin soldering iron nib.
    or I can do it for you.
  3. aragorn
    18,019
    716
    Mines temperature related. Some days its completely illegible, other days you car more or less work out what its saying with just the odd line missing.
  4. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    366
    54
    Mine too. On a long journey or hot day the display is worse.
  5. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,697
    642
    I got a new screen off ebay cost around £45, bit of a fiddly job but well worth the effort.
  6. ScottD3
    15,161
    1,121
    Heat makes a massive difference.
    Bring on the ICE!!
  7. HibiscusS4
    HibiscusS4 Member
    97
    I bought a cheap one from China for £35 and its still going strong 2 years on and looks fine. I used lots of flux when I solderedt to keep any bridges at bay. Use a heat gun to de solder the old unit.
