Why haven't I got a dong when it's cold?
danb986 Jan 27, 2012
  1. danb986
    danb986 In awe of VCDS Team Daytona
    523
    From the instrument cluster I mean :whistle2:.
    I was under the impression that when the snowflake symbol appeared (at 5 degrees I think) there should be an audible 'dong' to warn of potentially icy roads, like I had in my old Golf.
    After a bit of searching people suggested that it only happens when you're driving and the temperature drops down to 5 degrees, not when you start the car and the temperature is already below 5.
    But today I left work on 7 degrees and when the sleet started it dropped all the way down to 2. The snowflake symbol came on, but there wasn't a sound.
    Is mine faulty, or is it something that's just not there?
    Mine's an '07 Sport with the last of the red DIS's. It's got loads of menu's and options, including digital speed display and such, so I thought it would have an ice warning noise.
  2. mjr901
    mjr901 Guest
    no dong on my 09 plate S3. just a pretty snow flake. so your not alone... can't say it's really bothered me but each to their own
  3. cloughy
    cloughy Member
    515
    No warning sound on mine just the symbol (07 sport)
  4. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,760
    354
    "Do women know about 'shrinkage'?" - Jerry Seinfeld
    My 8L did a bong, my 8P doesn't. Probably something in the coding somewhere that you can get activated if you want, like the chirp when you lock/unlock.
  5. moag
    moag she's no d-turbo
    821
    35
    i often loose my dong in the cold
    WALTO TDI likes this.
  6. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Dong should be present, just less significant when cold.
  7. danb986
    523
    I'll get my laptop out and see if I can get my dong to appear :sly:
  8. shariain
    shariain Well-Known Member
    1,182
    190
    There are loads of web sites that can help with this problem
  9. CHEZ
    CHEZ moderately amusing Supporter
    4,172
    840
    your sort of right!
    you get the dong when driving and it drops to 5c and below!
    it does on my a4 anywho!
    but no dong if its already below 5 etc!
  10. danb986
    523
    Looks like it's just us A3 drivers that are missing out then.
  11. Khufu
    Khufu Well-Known Member
    5,704
    31
    I noticed when I swapped to a white led cluster that its not as loud as before. It definitely doesn't do it when you switch car on as I've just been out in it and its -1. Mind you, I'd quite like a bong when the ESP is working as you usually can't see the light because of the steering wheel angle :p
  12. CHEZ
    4,172
    840
  13. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    I don't have a dong when it's cold, should I be worried and see the doc? Ha.
    My 61plate doesn't bong, just shows the snowflake.
