Why Forge 007p
Lee172 Oct 17, 2010
  1. Lee172
    Lee172 GT3071
    430
    This may seem like a silly question, but why does everyone go for forge 007p? (or even any other aftermakret dv)
    Are there any gains over the standard dv? or is it just a case of the standard ones seem to fail ?
    Im trying to figure out whether or not to get one but there is nothing wrong with my standard dv(as far as im aware)so don't know if there is any point.
    Thanks, Lee.
  2. sportquattro
    sportquattro Active Member
    845
    51
    Theres no power advantages the 007P is just a better design and more reliable, but many run the standard DV with no problems, and you can replace a a standard DV about 3 times for the same cost as a 007p. 007p does look nicer though :eyebrows:.
  3. L4V15
    L4V15 Member
    37
    They leak over time.
  4. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,230
    2,046
    the spring can stick and the DV will be at least 7 years old
  5. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    I think most people go for this particular DV as it is specifically designed to operate with the VAG engines (Closed Loop / Recirculation Design) whereas some other makes of Uprated DV's don't work in the same way. I have one on mine with the YELLOW SPRING and it's been absolutely fine. Some people also look at the FORGE SPLIT-R as well which can give you the "whoosh" noise and offers the flexibilty to cap it off to make it quiet but I've heard that these are not as good to be honest.
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Plus there is the sheep factor......lol
  7. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Sheep syndrome usually follows (get it?) on from success, for example the RSTT wheels looking superb.
    The 007P is still a diverter valve, rather than an atmospheric dump valve. It means it will not cause any running issues with the VAG engines. They are reliable and can be uprated (spring colours) to allow for higher boost pressures from modified cars.
  8. finesse
    finesse Active Member
    2,805
    jd what happened to your remap, filter and dv?
  9. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Exactly my arguement for the 007P. It gives adapability over it's life. I have had the same one going from 210 bhp, to 260 bhp, and onwards past 300 bhp. Same valve, different spring.
    It just works for me....
  10. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    It's Forge. Forge is like God.
  11. Welly
    10,696
    129
    :lmfao:
    EDIT: Forge are reading this right now....
  12. JD09
    3,096
    46
    Unsure on where the car is going still, but seems to be head to just standard parts only chap. I have a green cotton filter, but for now, have no need for it to be mapped :)
  13. Lee172
    Lee172 GT3071
    430
    Is there any way of testing the diverter valve, i have done boost checks on the lower part of my intercooler pipework but the upper bits where the dv is doesnt work because the air just escapes from the airbox/filter?
  14. finesse
    2,805
    lee
  15. Lee172
    Lee172 GT3071
    430
    Thanks for that finesse, i will give it a go tomorrow. Depending on what happens ill get a 007p. Does anyone know a cheap place to get the 007p? Also my car is at stage 2. Shoulld i get a yellow spring?
  16. Prawn
    11,602
    3,573
    yes, yellow spring for you sir
  17. sportquattro
    845
    51
  18. S3 Andy
    S3 Andy Member
    71
  19. 1animal1
    9,978
    or go to JBS who 9/10 will beat the awesome quote and you dont end up with a silly 007p with a MASSIVE Awesome logo plastered all over it :)
  20. CHRIS555
    1,970
    10
    I bought mine from JBS at Inters earlier in the year.....
  21. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    I got mine from Reuben @ Tuningwerkes. Tell him Troopa sent you. 0208 681 0208.
  22. S3KO4
    S3KO4 Member
    850
    I have used forge as well as standard and other after markets. but went back to standard. as it does the job just fine. I am runing full stage 2. with no issues for over a year and stage one before that. the car keeps the boost up with no issues. plus the rs4 2.7T uses two of these so If there was a fault then AUDI would have redesigned something stronger. ps I have seen them on another RS4 runing close to 600BHP. :)
  23. Lee172
    Lee172 GT3071
    430
    I may pop into tuningwerkes as it is only down the road from me. Are you local to croydon Troopa?
    I took my dv off today and had a bit of a play, when i push the piston up and put my finger over the vacuum.. the piston slips down hhalf way then holds, then when i let go it will drop the rest of the way. Is this normal or is it leaking?
    S3ko4 i remember you saying at ace cafe you had a standard dv, but at the moment i seem to be having boost issues and am trying to find if the dv is the problem, my boost seems to hit 1.4 bar then drop to 1.0 straight away. Some times it drops to about 1.2 and holds. Although today i see it go to 1.5 bar and drop to 1.2.
  24. finesse
    2,805
    lee, what good vag mechanics in SE London?
  25. Lee172
    Lee172 GT3071
    430
    I know a guy in croydon that does golf stuff but is very good with 1.8ts. Other than that i think amd in woking is the closest that i know of.
  26. finesse
    2,805
    tuningwerks seem to have good reviews
  27. Lee172
    Lee172 GT3071
    430
    Yes they do but i went there to get a trial map before which ended up being more hassle than it was worth. I couldnt comment on the actual mechanical work they do though.
  28. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Reuben at Tuningwerkes is a top guy. Tell him Troopa sent you and he'll look after you. I've known him for years now after he worked on my bro's car back in the day and he's good friends with couple of my friends.
  29. finesse
    2,805
    troopa, is that your street name lmao
  30. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    I'd recommend Dean at 4rings (www.4rings.co.uk), they're a mobile outfit based near dartford so not far from you. Very good service and good prices too.
