Why does the car turns off when...
abdus Aug 7, 2008
  1. abdus
    abdus Top Gear VCDS Map User
    1,827
    .......aircon is switched on on idle.
    The revs start to drop and then car turns off.
    I have run vagcom and there is no fault codes.
    Any help please.
  2. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    There is an idle speed compensator for the load placed by the AC compressor. Its clearly not working.
  3. abdus
    1,827
    where is that exactly?
  4. rickparmar
    rickparmar Active Member
    2,285
    in the car:lmfao:
    sorry i have no idea
  5. abdus
    1,827
    FAIL....
    should be in the engine compartment[​IMG]
  6. HTC
    HTC Active Member
    3,428
    9
    When the aircon is switched on the ECU logs the change. Idle should be increased via the throttle body. If that isn't occuring, either the throttle body requires cleaning an re-aligning or you have a vacuum leak.
    Is your idle at all lumpy when the AC is off? Idle can be adjusted to raise it a little. Not sure if there is a separate idle setting for when AC is on, probably not.
  7. jojo
    28,908
    3,564
    Whilst on this subject, don't suppose you know if a 1.9 PD diesel motor has the same sort of thing? I'm having issues similar with my Passat.
    Thanks.
  8. abdus
    1,827
    idle is perfect when aircon is off.
    it only happens when aircon is on and some random times, it doesn't do it at all.
    I followed steps regarding throttle body re-alignment on vag-com, it said all was fine ADP OK etc...
  9. Caesium
    4,879
    Yes, if i remember correctly, there is a throttle bypass valve which opens and controls the idle speed, it get shitted up and needs cleaning out.
    I may be thinking of another engine, maybe someone with EKTA installed can look at the intake diagram and confirm?
  10. abdus
    1,827
    all sorted...
    throttle body needed a clean :)
  11. Caesium
    4,879
    oven cleaner is the best stuff to clean them with...
