Why does my car every now and again start screaming?!
wolfy1988 Jul 10, 2011
  1. wolfy1988
    wolfy1988 New Member
    turned it on today to be greeted with a very strange screaming motor noise coming front he engine bay.
    Its not the engine itself more something in the engine bay
    Ideas?
    J
  2. a3tdi2001
    a3tdi2001 Member
    437
    Sounds like your auxiliary belt might be loose. You can sometimes isolate the problem by squirting a wee bit of water on it when the engine's running to see if it stops doing it for a bit.
  3. wolfy1988
    Its a very intermittent sound and very load. it does not sound like a belt either
    J
  4. <tuffty/>
    21,869
    4,198
    I have had a similar issue and it turned out to be one of the fans (the one closest to the battery in fact)... only happens on cold start an randomly
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    It sounds like the secondary air pump they can work loose in there housing
  6. wolfy1988
    THIS
    This is what it sounds like, big problem?
  7. s3dave
    10,110
    736
    Not really have a look under the car, the rivets work loose and it gets all rattley, you can glue it back, some people have deleted it its an emmisions thing, if it is this it should stop after a few mins from cold.....
  8. jay1601
    jay1601 Well-Known Member
    1,347
    73
    could be a sticky starter motor.
  9. quinnj2
    quinnj2 Member
    47
    +1 for the starter motor. Solenoid gets stuck and over time will kill the starter. Get someone under the bonnet when you start it to identify area of noise.
  10. SiGainey
    SiGainey Member
    506
    10
    Turn the air con off, it's probably related to one of the fans at the front...
  11. S3KO4
    S3KO4 Member
    850
    It's very common, and like mentioned above it most defiantly the starter motor
  12. DenCar
    DenCar Member
    404
    Yep ^
    DC
  13. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    another one for the starter motor seen it plenty of times.
  14. dannyh
    dannyh Nogaro S3
    795
    13
    Yep starter motor, mine does it, or did do it, only when it is cold so stopped now its summer allthought i am sure i will be greeted with it again come winter lol
