Why do my wipers not stop in 'service position'?
Chappy Sep 28, 2010
  1. Chappy
    Chappy Call me Dan! Audi A5
    471
    25
    Hey guys,
    My other Seats (Leon and Ibiza Cupra) both had wipers that stopped in the 'service position' and yet the Audi doesn't do it?
    Also is the wiring CAN_BUS? I had a bulb out the other night and it didn't flash up to tell me it was out?
    Thanks,
    Danny.
  2. sub39h
    sub39h Active Member
    2,502
    push the wiper stalk down less than 15sec (i think) after turning off the ignition. it's in the manual as far as i know.
  3. xnox202
    xnox202 Member
    193
    How long does the wiper stays in service position?
  4. Jonay
    Jonay Member
    274
    until you push the stalk down again after turning the battery back on through ignition.
  5. Chappy
    471
    25
    Yup, tried everything, they just don't do it?
    Danny.
  6. 8ig_steve
    8ig_steve Member
    39
    Out of curiosity I have just tried my 1.8T
    Ignition Off, Wiper stalk down, and up they pop
  7. edition
    edition Active Member
    1,426
    Make sure you don't put them in service position and crank them and them put the key back in...........
    TWANG!!!!
  8. mike foster
    3,967
    If the bonnet switch isn't working the ecu won't allow the wipers into service mode because it thinks the bonnet is up already !
  9. audicruiser
    audicruiser Audi Heaven
    1,865
    Go into the extended menu on the DIS and under "wipers" there is a setting to turn the service position on or off. Sounds like yours is set to off....
  10. Khufu
    Khufu Well-Known Member
    5,704
    31
    Not all models have that option on the DIS, mine doesnt.
  11. dickys3
    2,963
    23
    I used to be able to do it by turrning the ignition on, then off quickly, then by pushing the stalk down.
    I then activated the extended menu for the DIS using vagcom, and since doing so I cannot do it using the method above! I can now only do this via the DIS.
  12. audicruiser
    1,865
    No but Danny's should have it as it's a MY2009 car looking at his avatar pic...
  13. Chappy
    471
    25
    Yeah, it's the facelift, thanks for your help everyone! Audicruiser, I shall try tomorrow to see if the option is there, plenty of menus to have a look through, if not, it maybe the bonnet catch! Tried holding the stalk down this morning and still nothing :(
    Danny.
  14. micasb
    micasb Member
    327
    Hi there.
    I also activated the option in the DIS but it does not work for me... And it stoped working with the old method aswell...
    Any ideas?
