whos got the new style key?
vw754 Dec 20, 2010
  1. vw754
    vw754 vorsprung Durch Technik
    2,356
    59
    ive got the old style keys for my a3 and want to buy one off e-bay and i wanted to ask if you guys would be kind enough to check the key numbers and tell me what you have so that i can get one similar as ive found the a4 ones different,my numbers are HLO 8PO 837 231 on my old style keys at the moment....im thinking of transfering the immob chip over to the new key? if it will work.
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    afaik the new keys arent reprogrammable youll end up having to buy most of the bits again from the dealer
  3. Smoothie
    Smoothie Active Member
    1,431
    What's the new one look like?
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,128
  5. jungleman
    jungleman Well-Known Member
    2,035
    42
    im guessing they mean the one with the stainless steel strip down the side?
  6. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Team Brill Red Gold Supporter Audi A3
    7,270
    370
    yeah thats the new style one
  7. FranA3
    7,270
    370
    [​IMG][​IMG]
  8. NHN
    29,601
    1,782
    I did a thread on the 05 onwards keys that can be used on pre 05 8P's.
    You cant reprogram the megamos 48 chips on the 8P, so transferring or get a new one, but new one needs the vin & brand encoded on the chip before can be matched with car immo, you can buy the 05 onwards keys new from audi which will be coded 50 percent by germany then rest at dealer, which is how I did.
  9. mike foster
    3,967
    You didn't tell him how much mate !!! lol
    Actually there has been progress on this. My local VAG approved garage has a piece of kit, that has been approved by Audi, that allows them to read the one 'bit' of information that Audi Germany encode. He also has the laser cutting gear to cut the new key. He needs the car for about half an hour to scan for this info. and can then reprogram everything (apparently ! )
    I will let you know how I go on and how much he charged because I already bought the key fob off ebay 12 months ago.
  10. PH1L
    PH1L Gievf Buckets
    3,851
    40
    the problem aint reading the code theres plenty of kit out there to brute force it out, but however if he can program the key great, ive not tried mine yet
  11. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Do these new keys make your car faster?
  12. Dec
    Dec Active Member
    319
    30
    5bhp gains I've heard? :laugh:
    Wouldn't mind a new style key as I don't have a spare :unsure: but I think its in the region of £300?!
  13. NHN
    29,601
    1,782
    £300, which pipe you been smoking, £150 tops if that with price increases, I got cause I cant stand the older ones & they were fairly worn, plus I broke an immo chip lmfao.
  14. NHN
    29,601
    1,782
    I just did. post 13 :p
    I dont know of any vag approved aftermarket unit that can be used to drag the skc from the car, afaik only VAS units are approved by VAG Mike & even those dont take the skc anymore, they do it all behind the curtain as such now, no viewing of skc possible, if you have the name of the unit then be interested to know as I know of a number of devices out there in the wild.
    Also dont need a laser cutting tool, I've had all my keys cut by a metal cutting machines even by audi.
  15. vw754
    2,356
    59
    :applaus::asskicking:LOL !!!
  16. NHN
    29,601
    1,782
    Lmfao, hey it was the 1st go & that glue that sticks them in is a bitch to remove, ok not anymore as got the knack, but its well routed in the plastics.
  17. vw754
    2,356
    59
    whats best way to remove it how did you? im thinking getting the key off e-bay coding in the remote,removing the chip from my old key and hopefully its done!
  18. NHN
    29,601
    1,782
    You need to use a surgical type knife so its very thin & very very slowly work away at the glue by creating a channel next to the chip as such, you could dremel round it & destroy your old key, but any pressure against the glass chip will crack & render it useless, so try to work the channel so its not pressure against the chip & slowly/patiently you will get it out, done number of keys now with success, key is (scuse the pun) to be patient & not a bull in china....................
  19. vw754
    2,356
    59
    ok,thanks for that NHN il source a key now,aslong as i get the right mhz is that ok do you know? mine is HLO 8PO 837 231 hella -434 mhz the new one are 8p0 837 220D some start with 8E and some with 4 FO will they all be compatible,or have i got to match the mhz numbers? and get the one starting 8p0 ?
  20. NHN
    29,601
    1,782
    No, make sure its specifically an 8P key part number, 8E as in A4 etc wont work with 8P even if same frequency & same shape/look, take my word for that, the usual one for UK is the 8P0837220D iirc
  21. mike foster
    3,967
    Nige - you have PM
  22. NHN
    29,601
    1,782
    Ditto :)
  23. mike foster
    3,967
    Mine is 8P0 837 220 but doesn't have any suffix.
    Next line is 'Hella 434 MHz'
  24. brough74
    brough74 Member
    423
    22
    Mine is a later type key, its a 58 plate S3 if thats any help to you. They are a bit longer than the old type
  25. NHN
    29,601
    1,782
    That superseded to the D, but grab the D if you can
  26. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Do you need to declare these keys to your insurance company?
  27. paddy
    paddy Audi=we just sell em mate, we can't fix em.. Team Ibis Audi S3 Black Edition DSG
    5,445
    236
    Is it one of those old fashion things that you stick in a lock and twist ?...lol I expect one day Audi will go keyless like a 6 year old Datsun Micra. :laugh:
  28. NHN
    29,601
    1,782
    Datsuns have all been keyless Paddy, you have to wind the feckers up to run the hairdryers in them.
  29. paddy
    5,445
    236
    LOL...dont tell me the TT doesn't have a hair dryer as well :)..and curling tongs :)
  30. Khufu
    Khufu Well-Known Member
    5,704
    32
    Aye, Kessy for the new A3 model!
    TBH, i'd be happy to use my mobile phone attached to my wrist to unlock the doors & automatcally enable ignition system to use a start button or speak into my hands free - "unlock", "start", "stop" etc LOL
    mmmm, think my brains been out in the cold too much today!
  31. NHN
    29,601
    1,782
    The TT is a datsun in disguise, just goes to show those sneaky bloody japs are taking over the auto world huh
  32. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Do these keys affect the handling in any way?
  33. NHN
    29,601
    1,782
    Only if she knocks her head on them mate.
  34. mike foster
    3,967
    Been to the pub and logged back on to this thread and haven't a clue what's going on !! :think:
    Question :- How much for a spare key for my A3 MY2006 (new style key fob ) that actually works properly and doesn't cost Audi prices , and where can I get one ?
    I only got 1 with the car and need a safety net ( and also a spare key !) This boozing has to stop :crying:
  35. NHN
    29,601
    1,782
    Go back down the pub, you havnt drank enough Mike.
  36. mike foster
    3,967
    I think that's the bit that confused me !lol :crying:
    All the Datsun bit is irrelevant anyway (are they called Nissan now? ) 'cos I don't have a corner shop ! :sm4:
  37. NHN
    29,601
    1,782
    lmfao
  38. Ads
    Ads License to drive
    8,230
    613
    Soooo racist.
  39. NHN
    29,601
    1,782
  40. Ads
    8,230
    613
    That yours?
