Who's car rattles ??
PaulBelsham Jan 25, 2005
  1. PaulBelsham
    PaulBelsham Member
    My S3 may be 3 years old now but the interior seems like its held together worse then a 10 year old Escort. (well maybe thats a slight exageration)
    I get rattles from the armrest
    The passenger door card
    The parcel shelf
    The glovebox
    and the steering column
    Admitedly I am REALLY fussy when it comes to rattles and squeeks, and am probably making it sound worse then it actually is, but could it be that the cold weather is making the plastic brittle, or is my S3 turning into a shed ?
    Maybe I should buy a BMW /ubbthreads/images/graemlins/frown.gif
  2. Rob W8
    Rob W8 Member
    953
    I get a rattle from the housing on top of the steering column where it meets the instrument display. Its not an S3 (Unfortunatley) but I guess it is much the same. The rear creaks and little when I reverse off the driver and turn the wheels. I think this is something to do with the inner lining of the tailgate being a little loose.
    Other than that shes a beauty. If you think yours rattles you should have come out in my old 206!
    Oh yeah, the front speakers rattle, but thats cause they are sh*t.
    Rob
  3. SimonPoole
    SimonPoole Member
    30
    I've got an anoying rattle from the dash somewhere around the stereo and switches.
    I had a creak similar to the one you describe Rob, it turned out to be the catched for the rear seat back rest. They just needed lubricating and it's been fine since.
    Simon
  4. Rob W8
    Rob W8 Member
    953
    Cheers Simon, will have a look at that when / if the wife brings the car back from work.
  5. Markb
    Markb Active Member
    2,139
    My passenger seat rattles, but I think I know why that is LOL
    Oh yeah the drivers door rattles on mine.
  6. cybrey
    cybrey Member
    331
    I've got loads of rattles.. and I thought Audi cars were supposed to be put together well.
    My two most annoying ones are, the one from the passenger seat head rest, and the one from the door card on the passenger side.
  7. marctwo
    marctwo Member
    410
    No rattles but some squeeks. The driver's seat creaks, as does the clutch. Both started fairly suddenly and sometimes disappear so I blame it on the Weather. Having such badly maintained roads in the UK combined with stiff suspension can't really help the situation!
  8. Have a slight squeak where the CD player console meets the bit above the ashtray (not very technical I know).
    Easily cured with a spray of WD40 - this works on most squeaks and some rattles if you can track them down.
  9. imported_gek
    imported_gek Guest
    My drivers window makes a noise as if it's dropping (it's not, just a poor seal I think) when I hit a bump.
  10. Defratos
    Defratos YouÂ’re Dethpicable!!
    2,232
    My suspensions makes a squeaky noise when I go over bumps, but no interior noises so far.
  11. Garth_S3
    Garth_S3 Active Member
    308
    56
    Mines a 2003 model and is rattle/squeak free.
    The only thing I can mention is the drivers seat makes a slight creaking sound when I get in and out of the car, but when I'm in it's silence /ubbthreads/images/graemlins/smile.gif
    On the other hand.... I do get a slight whistle from the front windscreen at higher speeds. Can't really tell where the wind is whistling from though /ubbthreads/images/graemlins/frown.gif
  12. imported_ashs3
    imported_ashs3 Guest
    [ QUOTE ]
    Rob
    [/ QUOTE ]
    Same in my 2001 facelift S3, oh and the glove box rattles. Also the rear seat but I think that is either the parcel shelf or the seat belt housing arms being shaken by the rear seat?
    They are all worse when the weather is colder, once the car warms up they go away.
  13. stores
    stores New Member
    22
    mine 2001 A3 1.8T has a occasional rattle from the rear possibly the parcel shelf or rear seat area drives me crazy cos cant find anythin obvious will get the rattle police to investigate!!!!! Reading ashs3 reply might be the same area as mine will track the buggar down one day
  14. ImS3ola
    ImS3ola Member
    242
    I'm getting an annoying rattle from the rear/parcel shelf area as well. I've been meaing to get my mate to sit in the back whilst I drive over a bumpy road so we can isolate the source.
  15. Jodi
    Jodi Starsky
    45
    My S3 passenger seat rattles aswell. The seat back seems to have quite a bit of play in it. Anyone know if this can be fixed by tightening something up?
  16. stores
    stores New Member
    22
    Bit of an update on this post!!!
    After posting thread about rear boot lights not working decided to climb into boot upside down and fiddle with the bulb found it to be loose in the fitting put it back in correctly and hey presto still NOT working!!! The upshot being though that the rattle I had in the back of the car parcel shelf area that i could not damn well locate has GONE advice to all maybe look if bulb is loose in boot who needs light there anyway prefer not to have the rattle!!!!!
  17. richh
    richh New Member
    27
    Took mine in for the 80k service plus belt and water pump change - I know I know - should have done it earlier, but now my glove box squeaks - why the hell is that??
    RH
  18. BADDave
    BADDave Member
    37
    I have the mother of all rattles on my 1.8T Quattro!
    (1) I get a bit of a clunk/heavy rattle from somewhere underneath when I bounce over potholes at low speed.
    (2) After a longer journey I sometimes get a vibration and harsh sensation which seems to come from the transmission tunnel. This is noticeable when pulling away at low speed and I think I can feel vibration coming from transmission tunnel when I put my left hand back and down over it! It goes away at speed.
    The clunk over bumps (1) gets much worse when (2) happens.
    Beat that!
    Suspension, engine mounts, exhaust mounts and anti-roll bars have all checked out OK. /ubbthreads/images/graemlins/confused.gif
    Any ideas?
    (I already started a thread http://www.audi-sport.net/ubbthreads/showflat.php?Cat=0&Number=158170&an=0&page=0#158170 )
  19. Timbo
    Timbo Slowest car ever round the Top Gear track?!?
    275
    It's completely random!
    I had a very irritating rattle from the RHS of the dash behind the clocks somewhere, which has gone since I last cleaned the dash... go figure!
  20. jiffi77
    jiffi77 Member
    96
    My A3 1.8T Sport, has a rattle around the steering column, I think it's the plastic surround where the column adjusts, anyone know how to cure this as it's a pain in the backside.
  21. The Slug
    The Slug Active Member
    1,869
    [ QUOTE ]
    [/ QUOTE ]
    Passenger door was rattling, audi put a run of felt strips on the inner body of where the door closes too, and has solved the problem, on the rubbers around the door, i use a rubber treatment to keep the rubbers supple, do this ever 2nd wash and it'll be fine, regards the felt (anti rattle) tape, vagparts sell this stuff, and its cheap!!
    Other than that my car has bin pretty good, touch wood, lol.
  22. Floob
    Floob Member
    58
    I have the same thing in my 98 A3 1.8T, am going to see if holding the parcel shelf stops it.
  23. SanityClause
    SanityClause Member
    93
    99 S3 with 90k on the clock and no rattles or squeaks anywhere, just as it should be.
    Only downside points are as usual, first cold day this year (3 degrees C) and the coolant sensor kicked in, so I added a little more, problem solved.
    No doubt in the winter if I try adjusting the volume in the morning I'll get the radio at full blast til I hit the off button.
    If this is all I have to look out for in almost 4 years I'll still be happy.
    The S3 is pretty well screwed together, cheers.
