Who'd like a look at my logs?
vroomtshh Oct 11, 2012
  1. vroomtshh
    vroomtshh Active Member
    362
    49
    I'm having some problems with the car at high revs - 4500 and above.
    I did a few logs and have screenshots below.
    I never lifted my foot during the logs, yet it seems the throttle angle changes.
    It sounds and feels very much like a misfire, but I have new coilpacks, and plugs, so not sure what else could cause a misfire.
    No fault codes
  2. dplovin
    dplovin Member
    416
    I'd post this on the a3/s3 8l forum mate someone will defenately be able to help you there with this post
  3. vroomtshh
    362
    49
    Cheers, I will do. I think I know what it is now, but be worth checking over there
  4. pauldazzle
    pauldazzle Well-Known Member
    1,192
    95
    You either didn't get the engine up to temp or you have a goosed Coolant Temp Sensor.
  5. vroomtshh
    362
    49
    what makes u think that?
  6. pauldazzle
    1,192
    95
    Look at the Temp column.
  7. pauldazzle
    1,192
    95
    Failing CTS is a really common problem on VAG cars, & if the output to the ECU has gone down it'll cause incorrect fueling.
  8. vroomtshh
    362
    49
    I'm all new to logging but isn't that temp column for the IATs?
  9. pauldazzle
    1,192
    95
    Yes you are correct I hadn't looked closely, & didn't notice you were on measuring block 118.
  10. pauldazzle
    1,192
    95
    Have a look in measuring block 011 for coolant temp just to make sure it's ok.
