Who uses an AFR gauge and which one?
Scullies Jun 14, 2013
  1. Scullies
    Scullies Well-Known Member
    1,543
    657
    Been looking at an AFR gauge. Seems most popular wideband ones are AEM and Innovative.
    Was wondering what you use?
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    I think most of the guys on here use the AEM item, although I am led to believe that it mostly because it says poo on start up.
    slowcoach3 likes this.
  3. Scullies
    1,543
    657
  4. 16Klappe
    5,795
    1,183
    I don't really know to be fair, I just trust in my mapping and that my tiny turbo can do no damage.
    PT or Prawn are your best bet. I will link Prawn to this now for you.
  5. badger5
    9,321
    1,891
    AEM until now... I have had 3 of these fail now in less than 12 months... Not impressed..
    Trying a PLX one now
    Previously used VEMs combined afr and egt - baulky wiring at gauge my comment on those. Working ok tho.
    Zeitronix is what I use in badgerwagen for last 7 years... perfect!
  6. *P3nfold*
    *P3nfold* Member
    368
    15
    I used to use NGK AFR (NGK Performance Products - Powerdex AFX™) excellent bit of kit. This is was integrated into the map on my Emerald K6 ECU.
    Excellent reviews and extremely accurate. Jim @ JKM Performance mapped my car with it.
  7. burns3
    burns3 Member
    224
    17
    Is there any place in the uk that sells the zeitronix afr gauge you use Bill or can you only get them from the usa?
  8. badger5
    9,321
    1,891
    how much was it?
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    PLX here too
  10. jay1601
    jay1601 Well-Known Member
    1,304
    51
    i'm using a AEM, no problems at all with it
  11. *P3nfold*
    *P3nfold* Member
    368
    15
    Hey Bill, I paid around circa £160 as I ordered it from the states. PM me if you are interested?
  12. Chlippo
    Chlippo Member
    679
    15
  13. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Sorry to hi-jack slightly Darren
    These use feed from cars lambda yeah?
    Has anyone tried any of these gauge apps on android or iPhone?
    Do they give similar accuracy?
  14. Sam_
    Sam_ Down under
    3,029
    477
    Liquid gauge
  15. Scullies
    1,543
    657
    the aem and innovative are stand alone systems, they come as a kit with an oxygen sensor that needs a bung welded into the downpipe for fitment. I think the PLX is also the same but comes with a different type of controller box, the gauge is almost as thin as a tea biscuit by the looks of thing :D
    i have seen other types of gauges that take a feed off the signal wire on the ecu oxygen sensor, but these type of gauges sound dodgy to me. The oxygen sensor uses such a small voltage to take it readings, I think adding more hardware to the system might throw the reading out and if it does then the ecu reading will be wrong and it will try to correct things by adding or subtracting fuel when it doesn't need to. Well that's by theory and I may be wrong.
  16. StaceyS3
    StaceyS3 Well-Known Member
    2,487
    466
    That blends with the clocks really nicely....now another one on my list and already couldn't make my mind up which one to get
  17. Pedrosousa
    Pedrosousa Member
    174
    I'm using innovate MTX-L, I had three with problems not a good choice....
  18. jonno123
    jonno123 Member
    99
    i use a techedge 2j2 imo the best you can buy around £300
    i have wired it into my emerald k6 , for closed loop/adaptive mapping ,
  19. Scullies
    1,543
    657
    Im still undecided on this one. Not sure if a like the digital read outs, think I prefer the needle sweep style - Yes, you can call me old and unfashionable!
  20. badger5
    9,321
    1,891
    best you can buy for what reasons?
    Its double the cost of an AEM for example...
  21. badger5
    9,321
    1,891
    You are old and unfashionable
    Scullies likes this.
  22. jonno123
    jonno123 Member
    99
    it can do data logging (if you want) and is very accurate compared with the bosh industry standard lambada kit we use a work and its reliable
    Aem is all so a very good bit of kit as ive seen many of people using it
    it all depends what you are using it for
  23. badger5
    9,321
    1,891
    The sensor is Bosch conventional lambda yea?
    Logging is done by my Dyno software, from analogue input from the AFR gauge.. all measurements in one place then, and recorded against dyno runs for pressures, temps etc etc
    Trying to figure whats more accurate about this one you mention. Measurement wise.
