Who loves boost leaks?
Welly Apr 29, 2010
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Yay. A new boost leak to hunt down and sort.
    Appeared last night driving over to Trowbridge whilst racing (to 60) some nobber in a Jag.
    Quite pronounced and loud, but only when on full boost! Not going to be an easy one to find me thinks.
    Damn it!! :mad:
    You'd of thought after a few months of having this cooler, I would of had all the leaks pegged down by now!!
  2. Prawn
    11,606
    3,582
    odd that you keep getting leaks Welly, what clamps are you using?
    I had lots of problems with leaks and hoses popping off at 22psi on my AGU, when using Mikalor clamps.
    I switched to JCS Hi-Torque jubilee style clamps on advice from Forge, and I've not popped a single hose since!
  3. 1animal1
    9,978
    i think Welly is an attention seeker :p
  4. Welly
    10,696
    129
    They're pukka Jubilee ones - 70 - 90 mm. They cost me a bloody packet as well :-(. To be honest, the pipework assembly is tight as a gnat's ****, so I think engine movement causes it eventually.
    I'll just take the bumper off and inspect. Its always one of a few places - mainly where the pipework leaves and comes into the engine bay. Also the MAP sensor pipe. May be time to invest in a real one.
  5. Welly
    10,696
    129
    Now that's not very nice :(
    Hurt my feelings now and everything..... LOL.
  6. Matt82
    Matt82 Active Member
    2,365
    i put a complete silicon hose kit on the s4 when i bought it. total clip count was in the HUNDREDS.
    when i did the cambelt job i could tell straight away i wasnt getting the boost response, i had disturbed a pipe or two.
    since i did those, i get loads more mpg and the car is nice and fast now
    not tempted to get a boost leak kit welly?
  7. <tuffty/>
    21,680
    4,107
    Book it in for a Badger5 boost leak test (tm) :icon_thumright:
    I must say the Hi-Torque clips are really good and worth the investment... more so I would say than the Mikalor types simply because you can get a proper feel for when the things are tight whereas the Mikalor t-clamps just seem to keep tightening until you end up crushing the pipes without realising...
    In my experience, the biggest contributor to 'popped' hoses is the lack of bead rolled edges on pipes and leaks are usually due to overtightened T-Clamps either crushing pipes or not the right size and reeving up thus not clamping uniformly or just not being tight enough (jubilees or t-clamps)
  8. Welly
    10,696
    129
    Oh, they're all tight enough dude, believe me. As tight as I dared without getting click of death.
    All the hard pipes on mine have rolled edges, and there isn't a popped hose - all hoses are present and correct - there is just a leak somewhere. Only under big boosty plops though. Weak join somewhere.
    On a side note - the PCV hose from the inlet manifold - can I block it off for testing? What are long term effects of doing so?
    I 'manufactured' a hose to replace mine - but in all honesty, it is gash, and I'm not sure how well it's standing up to the punishment I give it. I don't mind spending money on things, but £20+ from the stealer for that bit of rubber is just too excessive for me to swallow.
    With regards to a boost pressure test, I did PM Bill as I wasn't sure if he did them or not. But to be honest, I like to find and fix problems myself, as it is far more rewarding!
  9. Prawn
    11,606
    3,582
    perhaps Jesus hates you Alex?
  10. <tuffty/>
    21,680
    4,107
    Favourite place to leak is the joiner coming from the first silicon hose to where the old drivers side SMIC is... joiners are easily crushed...
    In your case though I would check the pipes coming off the the inlet mani especially the PCV as you have mentioned... I removed/replaced most of mine but the silicon split (again!!) giving me a vac leak but not a boost leak so it wouldn't surprise me if the same has happened here... bloody pipes are a PITA and I will be removing all that I can and using a catch tank...
  11. Welly
    10,696
    129
    That statment always makes me think of a bit of Simpsons dialogue...
    Homer: "At times like this, i look at my bracelet" (says WWJD)
    Lisa: "Your right dad, What would Jesus Do?"
    Homer: "Jesus? I thought it was Jepetto?"
    Arrrrrgggghhhhh. No-one ever calls me that. Except my mother. And then when I've been bad, it's Alexander! LOL.
    Not even my missus calls me Alex. How weird is that!
  12. Welly
    10,696
    129
    Yarp, check the FPR piping and DV piping by blowing and sucking down them (no jokes please...). DV is functioning perfectly.
    I have problems all the time down the section you mentioned actually - I shall be looking down there as my first port of call.
  13. 1animal1
    9,978
    she doesn't call you Tim does she :)
    sorry dood tooo easy ;)
  14. Welly
    10,696
    129
    LMFAO! :lmfao:
    Picking on me today aren't you! :motz:
    Thats OK dude - looking at her past... It wouldn't shock me.... LOL. :icon_thumright:
  15. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    How did you indentify a boost leak then? Sound, power or just from le boostage guage?
  16. Welly
    10,696
    129
    Sound and powerrrrrr loss. No boost gauge in my S3 - which is something I must pull my finger out and do.
  17. Prawn
    11,606
    3,582
    I know, I thought it would have more impact this way :)
  18. Welly
    10,696
    129
    Well judged! :icon_thumright:
  19. finesse
    finesse Active Member
    2,805
    Feecking boost leaks, doesn't help when your not mechanically "fingered"
  20. Prawn
    11,606
    3,582
    "The Fingers You Have Used to dial Are Too Fat. to obtain a Special Dialing Wand, Please Mash the Keypad with Your Palm Now."
  21. finesse
    2,805
    :ninja::ninja:
  22. sportstractor
    sportstractor Chugger
    2,709
    lol,
    strange how they do pop off tho considering you can easily hold 22psi back with you hands. Like you say movement is probably the cause, although silicone connectors should allow for alot of movement. might be worth checking the pipework so nothing is under any kind of stress, although im sure you have already thought of this... lol:icon_thumright:
  23. <tuffty/>
    21,680
    4,107
    While hoses and clips will hold the pressure as such, bear in mind the pressure typically fluctuates under boost/off boost application and will eventually 'walk' the hoses off the end of a pipe... having a rolled bead will prevent this from happening while the tightness of the clamp will seal enough to prevent air from leaking.
  24. Welly
    10,696
    129
    I think I may of cracked it actually. Well hopefully.
    Noise has now altered when I popped into Bristol to get some lunch to a squeak sound - meaning it's deffo a leak.
    It also sounds under the bonnet.
    I have a vague recollection of - when putting the engine back together - putting the red top hose on to the turbo and tightening up the jubilee clip, then getting 'click of death'. At that point (wanting to start it) I thought I'd replace it later.... And then never did. Hmmmmmm.
    I've since had the REVO map turned up as well for more boosty.... And I've always thought there may be a leak somewhere - but haven't been able to find it. It may just be that the leak has been getting progressivly worse since then.
    I shall look and replace shagged JB clip tonight - and then see what we're got.
    If not - off to Badger5 we go. :icon_thumright:
  25. Welly
    10,696
    129
    Found my boost leak.....
    Spot what's wrong with this.....
  26. finesse
    2,805
    charge pipe > turbo?
  27. sportstractor
    2,709
    thats the ******* pipe I can never get too. Do you wana come check mine welly?
  28. finesse
    2,805
    How much are they?
  29. 1animal1
    9,978
    oh no....thats a terrible looking pink pipe, get it changed for a much more manly black one....much less chance of it leaking then ;)
  30. 1animal1
    9,978
    its easy to get to if you remove the airbox and use a ratchet to remove the jubillee's.....just puts a nice strain on ya hamstring from bendin over....although some members wont have that issue ;)
  31. Welly
    10,696
    129
    Haha, no matter how much they are.....
    I have a spare. I've just had to go and pick S3 number 2 up from the office to bring home to steal the part off.....
    :eyebrows:
  32. Welly
    10,696
    129
    Pipe swapped - boost leak gone. Happy days :)
  33. MintyS3
    1,580
    Oooft. The Forge pipe is only available in red too...
  34. Welly
    10,696
    129
    I plan to replace with a good hose.... lol!
  35. <tuffty/>
    21,680
    4,107
    Sadly its an odd shape and size and the only aftermarket replacement I know of is made by Forge...
    Gotta love these cars and the quality pipes... although in fairness they are hitting that age where leaks are becoming more of a reality... bit like me ;P LOL
  36. Andrew@A.L.D
    3,879
    617
    I got a quote from Audi at just under £100 at the time
  37. Welly
    10,696
    129
    :faint:
  38. <tuffty/>
    21,680
    4,107
    About £50 ish for the Forge part...
  39. 1animal1
    9,978
    please excuse my sick inuendo style sense of humour Paul ;)
  40. finesse
    2,805
