White smoke misfire help !
Turbo_scotty Apr 20, 2014
  1. Turbo_scotty
    Turbo_scotty Member
    32
    my 3.0tdi 05 a8 has developed a heavey misfire/judder on idle if you rev is you can clear it and it smokes badly also (white) everything lead to injectors .
    I've recently changed injectors myself coded ect via vag com but still no joy no fault codes
    Although I have noticed that if you remove the swirl flap arm from the right bank and open it manually it runs spot on !
    So runs lumpy when closed on idle but runs fine when open I'm confused any help would be great
    Cheers Scott
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,116
    826
    Are the motors controlling the swirl flaps faulty, as its a common failure.
