White gunk on oil filler cap.
nickelvery May 14, 2007
  1. nickelvery
    nickelvery RS4 B5 380bhp
    545
    :jester: I checked my oil today and found it was low. I then took the filler cap off and found the dreaded whitish yellowish gunk on the under side. Now I know that it could mean head gasket.
    Any ideas.
  2. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
    It only means head gasket if most of your oil has white, or if the oil is sludgy and thick.
    It could just be moisture vapour mixing with the oil on the cap, so its not neccesarily serious.
    If the main builk is white it could be coolant mixing with the oil, have you been losing coolant?
    Do you use mineral or synthetic oil?
  3. nickelvery
    545
    No my coolant doesn't seems to have oil in and looks like a healthly amount too.
  4. Dave_Bayern
    1,913
    OK, check your oil filler cap is nice and tight, do an oil change, checking the condition of your old oil.
    If its runny but dark then its fine, if its chocolate coloured then bad things are happening.
    If it is fine, replace your oil with a fully synthetic, something like Fuchs Titan, Mobil 1 or similar, 0-40 or 0-30.
    If it continues to turn white, I'd start worring about head gasket but that seems unlikely if you arent getting through coolant.
    Oh, and buy your oil and filter from www.opieoils.co.uk, very cheap and very good.
  5. jcs356
    jcs356 Brum brum
    2,726
    67
    Been using the car for lots of short runs? If you are, it won't get to full operating temp and the condensation that forms naturally in the crankcase won't evaporate properly. Try taking it for a long run and then do an inspection.
  6. dan_a3
    dan_a3 Member
    196
    I would go by checking the oil on the dipstick, not just the filler cap. If you just have oil on your filler cap and not on the dipstick i wouldnt worry too much, may just be a blocked breather or something small.
