Whistling Noise Under Acceleration?
taylorc Sep 3, 2010
  1. taylorc
    taylorc A4 BE Quattro S-Tronic
    163
    23
    Hi all,
    I noticed today that under hard acceleration I can hear what can only be described as a slight whistling noise, it almost sounded like air either rushing in or out of somewhere within the engine bay (although it's not very loud).
    Has anyone ever encountered something like this or have any idea on what it could be?
  2. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    Is it rising pitch with engine speed? -the Turbo, perhaps?
  3. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Turbo spooling up or might be an air leak somewhere on the pressurised pipes.
  4. taylorc
    163
    23
    It does seem to increase with engine load (although on normal roads it's hard to test properly), if it was an air leak how much impact would it have on performance because I can't say I have noticed that much of a drop in straight line pull tbh
  5. DaveA3-TDI
    DaveA3-TDI Member
    249
    How do you know if you are loosing boost through one of the turbo pipes ?
  6. taylorc
    163
    23
    This is why I can't understand why Audi don't fit a boost gauge onto their performance vehicles, when I owned the Focus ST it was easy to see if there was any change in how the car was boosting but with the S3 you have to rely on VAGCOM (which I don't have)!
  7. DaveA3-TDI
    DaveA3-TDI Member
    249
    How do you check it with VAGCOM ?
  8. taylorc
    163
    23
    I believe that you can use it to data log boost pressures (as well various other feedback signals) whilst giving the car a run (although I have personally never done it myself, my car was data logged by the Revo dealer (not sure what software he used)).
  9. kkp0897
    kkp0897 Active Member
    771
    45
    In answer to your original post and like others have said, it sounds like the Turbo winding up mate. Mine does the same.
  10. taylorc
    163
    23
    Thanks for all the replies, I'm going to keep my eye on it but as some of you have said it does sound like the Turbo spinning up but if it starts to feel sluggish i'll take it in to get it looked at.
