whistle noise through speakers
S3 chj May 5, 2008
  1. S3 chj
    S3 chj Member
    306
    hi guys,
    iv got a whistle noise coming through my speakers i thought it was the turbo lol what causes this it seems to get a littel higher when i rev the car,
    cheers chris
  2. Rajiya_ne_Oudi
    Rajiya_ne_Oudi Member
    66
    Headunit is not earthed properly...
  3. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Presumably it's just through the rear speakers? Or if it's through all speakers then you must have the Bose system. The alternator whine is due to the Audi rear amp and the mickey mouse pre-out wiring they seem to think is good enough for a prestige brand.
    You need to rewire the rear speakers directly to the Alpine HU.
  4. S3 chj
    S3 chj Member
    306
    thanks Andy, i think it is only the rear ,i will have to disconnect the amp and rewire the speakers to the head unit,
    also where is the best place to store the brain for my radio, as its under the seat at the moment and gets in the way,
    cheers, Chris
  5. AndyMac
    9,832
    46
    Behind the glovebox, there's loads of room.
  6. S3 chj
    S3 chj Member
    306
    cheers andy :rock:
  7. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
  8. NHN
    29,568
    1,779
    Yeah this is usually earthing issues related so do some fault finding fella.
    Is it Bose?
  9. fran-s3
    1,103
    im getting some buzzing whining, with full bose... checked earthing no joy! considering this not sure if it'll work
  10. NHN
    29,568
    1,779
    Its gotta be a bad earth/grounding mate, its one of those long winded cable tracing jobs by the sounds of it I'm afraid, but more often than not if using audi original kit its earthing issues when whining noise through radio, have you anyway of testing another radio as have known this to be the cause, anyone local with same head unit able to help????
  11. fran-s3
    1,103
    Right, wel I have a alpine xda-001 unit so its not standard audi... My local ice shop recommended using a ground loop isolator, not sure if it'll do the trick though...
  12. NHN
    29,568
    1,779
    Ah sorry I didnt know you had changed I thought that was Chris, well I would listen to andy as he does seem to know more than us all, but usually whining is bad earthing as had it happening on other manfucturers aswell years back before I learnt the way of the force(VAG cars) that is, all same reason for fault, but he seems to be wiser so follow him.
