Whining noise
MPP Oct 30, 2010
  1. MPP
    MPP Member
    87
    Hi Guys
    I've got a whining noise. It happens at low rpm more noticeable when pulling off and 2nd gear. If I rev it in neutral you can also hear it.
    Any idea's?
  2. sub39h
    sub39h Active Member
    2,502
    don't drive with your gf in the car... or turn the radio up
  3. mike foster
    3,967
    Sounds like the famous turbo whine on that engine (BKD) ! Some people describe it a sounding like a police siren.
    Maybe a pipe loose or leaking (hopefully) rather than the turbo.
    Mine does the same but you get used to it .
  4. MPP
    MPP Member
    87
    Yep that's the noise.
    Is it something to worry about?
  5. mike foster
    3,967
    Don't think so really. From the threads on here loads have the same problem.
    I've done 71k and it hasn't changed in past 12 months. Take it to a VAG dealer if you're worried and get them to check it. Loose pipe or connection most likely.
    Only if it's the turbo do you have a problem but the car will have shown signs of going wrong - probably 'limp' mode or similar.
  6. NHN
    29,295
    1,701
    Not unless you notice any power issues.
  7. a3dee
    a3dee Guest
    There is always a whining noise on here,
    & its usually Paddy.
  8. MPP
    MPP Member
    87
    Ok. I'll see how it go's then.
