Whine noise from front end - speed related
1210tech Mar 31, 2010
  1. 1210tech
    1210tech Four Ring Fanatic Team Daytona Team V6 Audi A6 Audi Avant Owner Group S-line owners group
    696
    Ok, along with all the other bits and bobs that have gone wrong on my car in the last few months I now have a fault that is very worrying.
    On the M40 today I noticed a whine from the front. The pitch of the whine is definately road-speed related, not engine speed. It becomes noticable at a low pitch at around 30 and increases in pitch as the roadspeed increases.
    Its like humming a constant note (yes it's that annoying ), it's not a high pitch squeel, definately a whine.
    The pitch is the same in all gears 60mph 4th,5th,6th etc.
    It's the same pitch if I engage the clutch and pop it out of gear and let the engine revs drop off at this speed so it's definately not engine or turbo.
    It doesn't sound like a wheel bearing to me but i jacked up the front to see if it was a bearing but both left and right front wheels seem fine, no play and no obvious noise when spinned up
  2. A4 nut
    A4 nut Member
    351
    What about cv joint?
  3. 1210tech
    696
    I dunno, another possibility, just hoping its not the diff!!!!! :(
    edit: don't think its a cv joint as there is no clicking/knocking noise
  4. paul20v
    paul20v Audi fanatic
    1,113
    If its not a wheel bearing , my next guess would be the pinion bearing in the box the drives the crown wheel on the front diff ,
    not what anyone wants to here
    but you deffinately need a second opinion with someone direct listening to it as all forum suggestions are guess work without listening ourselves .
  5. johnswales
    johnswales Member
    65
    hi does it sound like loudish road noise coz my 2.5tdi has started to do this over the last few months its doing my head in its worse on a motorway thn a norm road hope it aint the diff any ideas please let me no.
  6. 1210tech
    696
    taking it up to midlandvw tomorrow so i'll let you know the news (most likely VERY bad) when i get back, fingers crossed everyone :)
  7. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    Could be the Diff.
    Mine has been doing this for a while now, something im going to have to get looked at. I thought it was a wheel bearing but had them checked and they were fine...
  8. 1210tech
    696
    yeah, i'm slowly starting to think that its gonna be something to do with the front diff, just found this and the symptoms description seems to be similar: Audi Quattro Driveshaft Repair
    From reading the above it looks like it might be the Centre Support Bearing that needs replacing
  9. J7USS
    3,737
    77
    hmmm yeah Im thinking this is whats up with mine too...Oh S**t.
    Keep us updated mate, im keen to see what the damage (the bill) is if it is that!
  10. Broken Byzan
    13,237
    465
    It will be the diff if it' a 6 speed, saldy quite common for the pinion bearing to go on the earlier ones. Some say it's due to too much preload being set from the factory etc, but Audi will not admit anything
  11. 1210tech
    696
    any idea of cost if it is that? cheers
  12. johnswales
    johnswales Member
    65
    a bloody fortune probs
  13. 1210tech
    696
    just got back from MidlandVW and they reckon it is the front n/s wheel bearing so its booked in for next week to be done which is a relief that its not the diff or driveshaft
    the lesson I have learnt from this is don't try and diagnose the fault yourself if its something you're not sure about, I have been going out of mind fearing the worst cause I was certain it wasn't a wheel bearing when all the time it probably was :)
    anyway, once its done we'll know for sure
  14. J7USS
    3,737
    77
    Dont wanna bring you back down mate but thats what they thought mine was to but it still made the noise after....
    BUT fingers cross you have better luck than me and hopefully it is the bearing.I guess we'll find out!!
  15. paul20v
    1,113
    Im in the middle of rebuiling a 6 speed for a customer , hope it the wheel bearing for you thou .
  16. 1210tech
    696
    It gets worse!!! :(
    When I booked it in for the wheel bearing I thought I might as well get the cambelt done at the same time as its due for one and the oil leak sorted as its making a right mess of my drive....just had a phone call, they removed the sump to replace the sump seal only to find little bits of metal in the sump that obviously shouldn't be there, so then removed the rocker cover to find that the cams have disintegrated (AKE chocolate cams!) and need replacing, BRILLIANT!
    The mechanics words were: "I can't believe its still running!"
    Anyone know where I can get cheaper replacement camshafts from because at the moment I'm looking at approx £300 each + labour? :crying:
  17. simon.m
    simon.m Active Member
    2,747
    where abouts are you i can get trade on parts if your near me im in thanet in kent
  18. 1210tech
    696
    Thanks, I'm in Birmingham mate
    Just spoke to the mechanic and both sides are fubar'd
    Gonna need:
    Full cam set £860 inc vat
    Set of Levers £185 inc vat
    Set of Lifters £185 inc vat
    Spacers £65 inc vat
    Total = £1295 + labour
    If there is anyone breaking a vag car with the AKE 2.5 V6 TDi lump please get in touch as I know that engine is used in quite a lot of different models
  19. simon.m
    2,747
    sorry mate have you thought about look for a secondhand engine mate off ebay or some where like that
  20. 1210tech
    696
    yeah, been looking for an engine or cylinder heads with bits in, I have a found a 2.5 tdi cab on ebay thats being broken but its a 2005 so not sure whether the parts would be the same.
  21. 1210tech
    696
    Think I may have a found what looks like a very good source: AW Engineering
    They do full camshaft kits at approx £180 each cam
  22. simon.m
    2,747
    well thats a step in the right price good luck mate ill keep eye out for you
  23. quattrojames
    14,050
    578
    This is a similar problem I was faced with 18 months ago. In the end it looked to be cheaper for me to replace the engine than try and rebuild it with labour costs etc, and you need to be sure that you have every last bit of swarf out of all the oilways etc.....
    There's an AKE on eBay at the moment HERE
  24. 1210tech
    696
    the engine is fine apart from the cams wearing down, its down to high mileage and the soft AKE cams unfortunately, my car has turned into a motorway work horse, plus I can't really afford a new lump.
    Just found a full cam kit with rocker arms, lifters ect for £550 so things are starting to look up, will just have to take a chance on the engine being flushed thoroughly before being put back together :icon_thumright:
  25. A4 nut
    A4 nut Member
    351
    If you rebuild it get a magnetic sump plug!
  26. quattrojames
    14,050
    578
    I had a lot of hassles getting mine running right, and it cost me a lot more than I originally anticipated, so there's a lot to be said for 'Better the devil you know'!
  27. 1210tech
    696
    yeah, thats what I thought. Its an independent specialist thats doing the work and they have done a few cam rebuilds on 1.9 tdi and 2.5 tdi's so theres no issues there.
    The mechanic said the lump and ancillaries are all pretty sound its just high mileage that caused the problem, nothings gone bang and the engine was still running ok, although as it turns out not too far away from going bang, so gonna rebuild without doubt, just need to get the bits at the right price :)
  28. A4 nut
    A4 nut Member
    351
    Who is rebuilding it?
  29. JohnboyC
    JohnboyC Member
    858
    13
    I have a 2.5TDi and touchwood no problems so far as its done 63K miles......what mileages do the cars in this Forum subject have out of curiosity.....
    Reason I am asking is that I am probably going to be selling my A4 in 18 months time.....and by then it will have around 80K on it.....
  30. 1210tech
    696
    Midland VW, Jody (the owner) knows his stuff :icon_thumright:
  31. A4 nut
    A4 nut Member
    351
    Yes know him you cant go wrong there!
  32. 1210tech
    696
    mine is mega mileage, just done 200k
  33. 1210tech
    696
    yeah, he has done all the major work thats needed doing, wouldn't take it anywhere else, in fact a few of my mates have got vw's and audi's and I send them all to him, quality mechanic ;)
  34. swine
    swine Member
    116
    mine is a 2001 2.5 quattro ake, 114500 miles on her now bought two years ago with 80,000 on it, i reckon mine had similar problems as when i was checking an oil leek i took the pan off and found a rocker arm in two pieces. i removed both rocker covers and cams were fine and all arms present. soft engine, bloody expensive to fix, love the sound of the v6 tho
  35. quattrojames
    14,050
    578
    Mine was 128k when it self destructed (timing problems caused the weak cams to break) and is nearly at 145k now.
    Your is an 03/04 John? It will be 8 or 9 years old by the time you sell - and there won't be many about with 80k on I wouldn't think :icon_thumright:
  36. simon.m
    2,747
    is this just a v6 problem ?
  37. A4 nut
    A4 nut Member
    351
    Have you mentioned this ask his for some discount for asn members he has got a good name on here print this and show him im sure he can do somthing.
  38. quattrojames
    14,050
    578
    No - the 1.9 is an incredibly weak engine. It's a case of when, not if.
    (joke)
