Which wire to use for the dimmer function on my AFR guage...
S3 Paul Jul 17, 2010
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    Ive fitted an AFR gauge in the drivers side air vent but wasnt sure as to which wire i needed to splice into for the dimmer function to work ( it is reflecting on the drivers door window ) i dont mind if it is dimmed all the time but will have to move it if i cant work it out.
    The gauge does have a wire to connect to the headlight wiring to dim it when i put the lights on... Is this a live feed or earthing out?
    Does anybody know which of the wires on the head light switch will work please .
    Many thanks.
  2. BigD-a3tq
    BigD-a3tq Member
    69
    Hi Paul
    The blue/gray wire is your variable power and the brown is the ground, i used this guide here...http://forums.vwvortex.com/showthread.php?3003612
    on another note..i was the guy at inters with a boost problem i took it to Jabba a couple of weeks later to discover it was a duff map!!
