Which way round does the Bosch DV fit?
mike-a Jul 28, 2011
  1. mike-a
    mike-a Member
    103
    As title.
    I'm going back to a Bosch DV from my Forge split-r but can't remember for the life of me which way round the Bosch valve goes.I've found this pic:[​IMG]
    Is that correct?
  2. Bradderz_1988
    3,899
    230
    yes so vac line is on the side pointing to the o/s wing or you can reverse it so its at the tip.
  3. Oranoco
    Oranoco Well-Known Member
    3,786
    344
    ^ What he said
  4. aragorn
    17,874
    686
    So long as the "pressure" is applied to the side port you can put it whereever you like. If you put pressure in the bottom it probably wont last long.
  5. Bradderz_1988
    3,899
    230
    I have my 007p fitted to the TIP with pressure applied to the bottom port (opposite the vac line) and the side port to the TIP is this correct as this is how I've seen them setup on the S3/TT's as I can't really find any pics of them fitted to any longitudinal 1.8T's ??
  6. B5QUAT
    B5QUAT Member
    317
    13
    What causes it to knacker up if you do it this way? Just curious.
  7. aragorn
    17,874
    686
    cant comment on a 007P
    as for the 710N, its something to do with the design of the diaphram inside the valve. If you put it the "wrong way" the pressure acts on the diaphram differnetly and causes it to fail sooner.
    I'll try to find the reference about it.
  8. Oranoco
    3,786
    344
    ^ Might well be the case with the factory item. All aftermarket items (atmospheric or recirculating) are designed to work with the presssurised side to the bottom.
    Cars are a funny old thing. It does actually make sense to have it the way Audi did though as the positive pressure will actually force the diaphragm shut.
  9. aragorn
    17,874
    686
    yeh, aftermarket valves are usually fitted the other way to the 710n.
  10. Oranoco
    3,786
    344
    They only do that to confuse the Hell out of us though lol
