Which upgrade headlight bulbs for my 53 plate b6?
allyp Jan 12, 2011
  1. allyp
    allyp Member
    222
    Hi as above which bulbs should i get to upgrade the headlights on my b6 ,they are poo lol,quantity would be helpful too please cheers ally
  2. Martin1981
    Martin1981 New Member
    I went for Osram Night Breakers for my dipped and main beams. The main beams are awesome but the dipped are still not great. I might get a HID kit sometime to replace the halogen dipped bulbs.
  3. allyp
    allyp Member
    222
    Thanks m8 ,i was looking at them H7 are they ?
  4. simon.m
    simon.m Active Member
    2,747
    yes they are h7 mate but id say dont bother just put HIDs in it you will in the end :)
  5. allyp
    allyp Member
    222
    Ill look into the hid kit,not heard that many good reports and means removing them for mot time mmmm
  6. simon.m
    2,747
    I don't no of any one on here that takes them out for MOTs as its not an MOT fail and there is a good few on here who's cars have been throu mot s with them in and had no probs at all :)
  7. allyp
    allyp Member
    222
    The new law im sure,they are being made illegal this year m8 ,may be wrong but sure i saw a link to the dvla site regarding it,think ill stick with the bulbs for now cheers for the info
  8. mja4cab
    mja4cab Member
    33
    I'd go for PIAA bulbs at demon tweeks, draw 55w and produce 110w. Had them in dipped and main beam.
    Realy good!
  9. quattrojames
    14,050
    576
    I've always heard good things about PIAA too, if I was going for halogen bulbs it would be them.
  10. crazypainter
    crazypainter Member
    594
    Am I right in thinking the dipped bulb and the main bulb are exactly the same spec as each other?
  11. quattrojames
    14,050
    576
    Yes, both H7's.
  12. allyp
    allyp Member
    222
    They sound good ,ill take a look thanks
  13. jbcalvin
    jbcalvin Member
    691
    21
    Slightly off topic, but can anyone confirm whether HID kits are going to be illegal, I was planning on fitting some factory spec 4300K ones to the new headlight units I have just ordered, plus how would an MOT tester know you had them fitted? Surely they just check the beam pattern and so long as that's OK the surely it should pass????
  14. Martin1981
    Technically they're illegal if you don't fit headlamp washers and an auto-levelling system. Most MOT testers will just assume they're factory fitted HIDs and as long as the beam pattern is ok then they'll probably pass your car.
    If you get stopped by the local constabulary and they book you for having xenons but no washers or auto-levelling then you can count yourself extremely unlucky. Same goes for an MOT tester being that picky.
  15. quattrojames
    14,050
    576
    There's a thread running at the moment with a link to the proposed new Mot Regulations. From 01 Jan 2012 they will fail an Mot, often the ballasts are visible and clearly retrofitted, if they're hidden under the light in the oem space then it would be harder to tell - although of course bulb colour and start up flicker are pretty obvious - especially if you haven't got washers and suspension levelling. Time will tell...
    Here's the thread:
    http://www.audi-sport.net/vb/a4-a4-...s/110328-do-i-have-can-bus-wiring-system.html
  16. JimLoskot
    JimLoskot Member
    160
    have just seen the price of them - WOW
    I've got the osram night breaker plus, they are noticably better than oem bulbs and can be had off ebay for just over a tenner for a pair
  17. way318
    way318 Active Member
    309
    32
    Would you have to take these out before your MOT and put standard one's in, due to them producing 110w?
  18. allyp
    allyp Member
    222
    Think i mite buy the night breakers too ,just looked at the piaa ones christ there dear
  19. way318
    309
    32
    Cheapest Osram Nightbreakers plus on ebay are £15.50 inc P&P, not checked to see if you can get them any cheaper anywere else.
  20. allyp
    allyp Member
    222
    thanks m8 so i need 4xH7 bulbs and 2x501 sidelight bulbs is that right ?
  21. JimLoskot
    JimLoskot Member
    160
    yes you're correct there, my mistake for scanning the page and making assumptions. Damn sight cheaper than the PIAA's anyway and give out a good light.
    got these on both of our cars.
    Think you'll struggle to find them any cheaper
  22. allyp
    allyp Member
    222
    cool away to order them now,thanks
  23. quattrojames
    14,050
    576
    Are the Nightbreaker Plus any brighter than normal Nightbreakers?
  24. way318
    309
    32
  25. JimLoskot
    JimLoskot Member
    160
    I think they just last a lot longer
  26. allyp
    allyp Member
    222
    well i ordered the bulbs so we will see if any good ,which sidelight bulbs would i need to match them 501s but shud i get the led ones or other thanks
  27. quattrojames
    14,050
    576
    Most people with HID's will run LED sidelights, hopefully someone with Nightbreakers can help with their colour. My Nightbreaker Fogs are very yellow next to my 6000k HID's.
  28. allyp
    allyp Member
    222
    ok cheers james
