Which suspension setup to go with
chaz20vt Dec 5, 2013
  1. chaz20vt
    chaz20vt Member
    428
    21
    Hi there after some advice really I'm looking to buy new suspension setup I'm currently running fk street coilovers which i don't rate at all there a harsh ride and the car doesn't handle great with the current setup so i was looking at a spring shock combo iv seen the bilstein B12 kit but it's nearly £700 posted as where the koni strt kit is arpund £460 posted and the Weitec kit is around £480 posted but what kit will be better quality from the koni strt kit and the Weitec kit?
    These are the kits I'm looking at
    Weitec by KW 20mm/15mm Ultra GT Lowering Springs & Shocks Suspension Kit S3 8L 1.8T Quattro 01/99> - £481.50 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension and per
    Koni 25mm STR.T Lowering Springs & Shocks Suspension Kit S3 8L 1.8T Quattro 01/99> - £465.00 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension and performance parts f
    Or this is a AP kit but that's cheaper again
    AP 30mm/20mm Lowering Springs & Shocks Suspension Kit S3 8L 1.8T Quattro 01/99> - £290.70 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension and performance parts for
    Any opinions people. ...
  2. Sean_S3
    Sean_S3 Member
    323
    17
    Of those 3 I'd say the Koni kit . I had the Weitec kit on my previous S3 and found it to be too soft and very similar to standard suspension. Got KW springs and shocks with 20mm drop now which feels more planted.
  3. chaz20vt
    chaz20vt Member
    428
    21
    Where did you find your suspension kit Sean_s3 ??
  4. Sean_S3
    Sean_S3 Member
    323
    17
    The Weitec kit I bought from DPM Performance , the KW kit I have now came fitted to the car. I think the Koni kit looks good , maybe speak to DPM and see which kit they suggest.
  5. chaz20vt
    chaz20vt Member
    428
    21
    I'm hoping Damien will post his opinions in this thread dpm don't list a kw kit
  6. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    I got my KW kit from Damian. Its excellent
  7. chaz20vt
    chaz20vt Member
    428
    21
    What sort of price was it? ?
  8. MUSH
    713
    12
    Same sort of figure as the weitec kit you've listed above mate.
  9. chaz20vt
    chaz20vt Member
    428
    21
    Dpm don't seem to list it anymore wonder if they can still supply it??
    How is the ride quality on your kw kit and how does it sit (looks wise)
  10. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Only fools would pay £700ish for the B12 kit.....I paid noticeably less than that.
  11. chaz20vt
    chaz20vt Member
    428
    21
    Did you? Could I ask where as the cheapest i can source it is £660 posted
  12. chaz20vt
    chaz20vt Member
    428
    21
  13. chaz20vt
    chaz20vt Member
    428
    21
  14. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    I've had those on my motor for about 1 and a half years now....if I had to choose again I would have waited another month and spent that bit more to get KW1s as I think my APs are in need of a refurb now- which is typical as the 2 year warranty run out very recently!
  15. DPM
    DPM Site Sponsor Site Sponsor
    4,987
    200
    If you're wanting a springs and shocks kit then I'd say the Weitec by KW Ultra GT kit is a very good option and one of the best all round kits on the market.
    Damian @ DPM Performance
  16. JoeeS3
    JoeeS3 Active Member
    464
    105
    43
    will you be selling your fk suspension chaz?
  17. chaz20vt
    chaz20vt Member
    428
    21
    What's the ride quality like with them is it harsh and crashy atall?
  18. chaz20vt
    chaz20vt Member
    428
    21
    Thanks for that Damien i did speak to you earlier I'm just unsure of what will be tje better ride quality and looks
  19. chaz20vt
    chaz20vt Member
    428
    21
    I will be when i decide what other kit ill be running
  20. JoeeS3
    464
    105
    43
    if you just pm me when you've sorted it all out then i'll have them off you :p
  21. chaz20vt
    chaz20vt Member
    428
    21
    That's fine still got to source a kit I'd be happy with first
  22. kwistof
    2,434
    535
    A lot less harsh and crashy than I was originally expecting them to be (I read so many stories about coilovers being super hard and crashy) but once I had the car fully poly bushed it all felt so tight and has given me a lot of confidence in the corners since it's all been fitted.
    I don't find mine to crashy or harsh but then again I also don't have them at a stupidly low ride height. When I had them fitted I had it set up for fast road use as opposed to park and pose lol
  23. chaz20vt
    chaz20vt Member
    428
    21
    Could you post a picture of what your ride height is like for me please
    Did you have standard suspension before these were fitted?
    I have my front wishbones poly bushed with Powerflex bushes
  24. S3Milky
    S3Milky New Member
    i am in the same boat as chaz here! wouldn't pay the value in scrap for the "fk street" that are on my car at the moment. on the arches it made the car, well like a merry go round but less fun, back end just wanted to let go all the time. at a the highest (i think -25mm) the car kind of behaves..so if you are running it on the bump stops raise it for the time being!! make best of a bad situation! :) defiantly helped me, looking at going back to struts. again on the fence between the weitec gt and the koni street, but i'm guessing both kits will ultimately be very similar and a improvement on the fk's.. out of interest how many of you guys are running adjustable tie arms??
  25. JimS3
    JimS3 Active Member
    736
    72
    I have had weitec coilovers, then H&R springs, then Koni springs, but now have Eibach Pro Springs with the Koni Str.t shocks and it's by far the most comfortable setup, and the ride height is spot on and even front and back.
    the koni Str.t shocks are very similar to the sport shocks, but not adjustable and valved between the medium and soft settings of the sports.
  26. MUSH
    713
    12
    mines the KW kit mate, but lets face it theyre the same company so the weitec by KW is KW...
    The ride is very comfortable for daily use yet a little firmer so gives good confidence in the twistys. Id highly recommend the kit and DPM. Damians a good guy, he'll see you right. Mines sits like this on 18s...
  27. chaz20vt
    chaz20vt Member
    428
    21
    What height in mm are your springs then mate as that sits nice
  28. chaz20vt
    chaz20vt Member
    428
    21
    I believe that the koni strt kit comes with H&R springs now
    So you'd recommend the koni strt kit would you? ?
  29. JimS3
    JimS3 Active Member
    736
    72
    If it comes with H&R springs then I would say you get some decent kit for the price.
    The Eibach Pro springs are more comfortable for a daily driver, but the H&R springs were pretty good too.\
    I had a H&R spring snap which is why I changed to Eibach, but I did hit a pot hole hard.
    I paid £149 for the Eibach Pro springs and £269 for the 4 Str.t shocks, so £418 total. (Plus new top mounts and bolts etc.).
  30. chaz20vt
    chaz20vt Member
    428
    21
    Where did you purchase these from at this price?
  31. JimS3
    JimS3 Active Member
    736
    72
  32. chaz20vt
    chaz20vt Member
    428
    21
    Thanks for that I'll look for Eibach spring somewhere else what mm are your springs mate
    And just to check you find this kit not to harsh or crashy?
  33. chaz20vt
    chaz20vt Member
    428
    21
    Buying them separately does work out a little cheaper as you say 75x2 for the front dampers and 57x2 for the rear dampers and Eibach spring are 178 so that makes it £442 instead of £465 which saves me £23 ....
    I wonder if the likes of dpm or awesome would match this as I'd rather buy from either of those really
  34. MUSH
    713
    12
    Mines the 20/15mm kit
  35. chaz20vt
    chaz20vt Member
    428
    21
    That sits really nice like that....
    I don't know what to do now I'm swaying towards kw kit or koni strt kit
  36. JimS3
    JimS3 Active Member
    736
    72
    Worth asking. If u don't ask you don't get!
    Think it is a 20mm drop, you want the Eibach pro kit, not the Sportlines.
    The sportlines lower 50 odd mm and on my mates golf are bone shaking.
    The Eibach pro springs are the most comfortable after market springs you will find, defo not crashy.
    I run them on my golf daily diesel too, lovely ride.
    Heres a pic of the front arch with Eibach, sorry don't have the back and I'm at work at the mo.
  37. chaz20vt
    chaz20vt Member
    428
    21
    And that's on a standard 17" wheel?
  38. JimS3
    JimS3 Active Member
    736
    72
    Its on 18" RSTT wheels, but the arch gap to tyre will be same with 17s.
  39. kwistof
    2,434
    535
    Yeah I had standard suspension before I had the AP coilovers fitted.
    Here are a few pics with my 18s I use for summer and my 17s for winter.
    It's pretty much as low as it can go with the standard rear tie arms- any lower and I'd need to buy adjustable ones.
  40. chaz20vt
    chaz20vt Member
    428
    21
    And you find the ride quality good with these?
