Hi Guys, looking for some sub advice.
I'm going to get one of Andy Macs stealth subs, 8 inch version. Only problem I'm having is which sub to put in it.
Currently I have a Rockford 12 inch sub (which I believe to be a relatively low end one, David R correct me if this is wrong) running off a 2x80RMS amp bridged (i.e. should be about 200RMS).
I realise I'm not going to get the super low bass the 12 can handle, but I'd like to get as close as I can. Andy has been using the 8 inch JL sub with good results. The 8 inch Rockford, however, is advertised as working down to the 4 litre volume of Andys enclosure, whereas the JL isn't. Hence I'm swaying between the two. The JL is apparently the better sub, but the Rockford is apparently suited better to the small enclosure, so it might be better overall.
Essentially what I'm looking for is any advice off folk who've had either brand in a v. limited enclosure. Also, a frank opinion on anyone who's compared the different sounds of smaller and larger subs.
/ubbthreads/images/graemlins/beerchug.gif
