which springs/shocks
egesford Feb 9, 2012
  1. egesford
    egesford Member
    346
  2. Jason.s
    Jason.s Active Member
    2,879
    348
    Kind of pointless putting on Bilstein shocks with unbranded cheap springs...I`d avoid the first and last line tbh.
    Also arent the B4 shocks just basically a standard replacement? Its the B8`s that are uprated? Could be wrong as i dont know all that much about Bilstein..
  3. egesford
    egesford Member
    346
    yeah the bilstein b4s area standard replacement, but i assumed they would be ok on a 35mm drop?
    and yes i was thinking the same, maybe i will avoid cheapy springs
  4. aragorn
    18,296
    804
    For the price, the second option is where i'd be spending my cash.
    B4's are "OEM" but afaik they are slightly uprated, as bilstein used to sell a "streetline" kit which had the B4 shocks and some ventura lowering springs. I had a set on my old nova back in the day and they were acceptable enough. Not bangy or crashy etc.
  5. Jason.s
    2,879
    348
    If you`re on a tight budget just get some decent springs and good condition second hand standard shocks if yours are getting tired?
  6. fingermouse
    fingermouse thats me
    3,998
    111
    You could ruin the car putting cheap parts on it imo
    Its always worth buying quality parts and knowing its done once done right
    After all you chose a Audi for a reason don`t put wishy washy parts on it.
    If you wanted a cheap car then Audi wasn`t the way to go imo.
  7. egesford
    egesford Member
    346
  8. egesford
    egesford Member
    346
    lol 'cheap' is one thing this car has not been. so far:
    clutch, flywheel, headgasket, valves, cambelt + tensioners, water pump, thermostat, glow plugs, egr delete, wheels, tyres, interior, service and remap. Thats what i can remember off the top of my head, only had the car since july
  9. Alais DJA
    Alais DJA Member
    559
    50
    Just got a set of Eibach Pro Kit.
