Which size brakes?
Ash187 Apr 12, 2011
  1. Ash187
    7,525
    759
    Hi guys,
    My car is due a service and i wanted to replace the brake disks and pads on the car...
    I have a 2.0 TDi 05 plate Sportback (sport model) and if i am right then this model has the smaller disks. (288mm i think)
    could i just buy the larger (312mm - Sline size) disks and fit them on as a direct replacement or would i need some other bits?
    I'm not looking to spend big money on it...
    any help is appriciated!
  2. Ash187
    7,525
    759
    can no one help me?
    I have the funds waiting to buy the brakes just need to know which ones to get?
    :3sadwalk:
  3. Adam.
    Adam. Meow.
    662
    34
    To fit larger discs you will need a different caliper carrier.
    Is it a 140 or 170?
  4. Ash187
    7,525
    759
    its a 140
    is there anything else i would need?
    thanks
  5. ~RS~
    ~RS~ Active Member
    1,466
    22
    I think you just need a set of caliper carriers and the disks/ pads from what I recall when upgrading mine, although I just got a set of mk5gti front calipers/disks/ pads and done a straight swap for the old ones. Not sure what a set of carriers costs alone cost
  6. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    ive just sold my 312mm fronts but have my 288mm rears discs and pads ( 2 months old ) and calipers and carriers for sale.
    email - r.menesse@yahoo.co.uk
  7. Ash187
    7,525
    759
    Are there any recommendations on what disks and pads to get if i just stay with the standard brakes? I have looked on ebay and seen some brembo disks... are these worth getting?
    Also whats a good company brake pads to get?
  8. ~RS~
    ~RS~ Active Member
    1,466
    22
    I see a lot of people getting the ferrado's can't remember which one's and green or red stuff pads.
    I just stuck to OEM stuff with mine from eurocarparts. Done the job nicely IMO.
  9. Ash187
    7,525
    759
    JUst had a look on Eurocarparts but i cannot figure out which pads would be needed on a 312mm setup... anyone know the right ones for that size discs?
  10. Ash187
    7,525
    759
    also will the 312mm setup on the front sit behind 17" ok? i am looking to get 18's but i would want to do the brakes first.
  11. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    The pads are the same between the 288 and 312 as they use the same caliper, it is just a different hanger that spaces it out to take the 312mm disc.
  12. Adam.
    Adam. Meow.
    662
    34
    Will fit fine. The Leon FR comes with 17's as standard and 312mm.
