which sensors control Fueling? 2.0TFSI
spider74 Aug 6, 2012
  1. spider74
    spider74 Member
    106
    10
    Tried posting this in the technical section but it seems very little interaction way down there!
    I’m looking to understand which sensors control the fuel mix on the 2.0tfsi engine.
    MAF, Coolant temp and what else?
    A4DTM 2.0TFSI Quattro
    My car seems to be running rich, it keeps fuelling on no throttle giving some burps etc on engine braking (which it didn’t before) and has a throttle lag then a sudden boost!.
    Also puffs some smoke out if you have been cruising on part throttle and floor it.
    It doesnt smoke at all on full throttle just a fter a period (10 mins) of partial throttle cruising I have VCDS and checked the throttle alignment and position sensors and they seem fine.
    Car makes boost and I have a boost leak test kit so it’s not a boost leak.
    Unplugging maf improves things so I cleaned it using MAF cleaner. Worked a little but not back to the way she was.Planning to use my usual "replace the cheapest thing first and work up to the most expensive" so any help appreciated.
    Car still drives great and is fast but something is not right. Happened when i was overtaking on the motorway a few weeks ago. Symproms were surging boost at mid throttle. I can drive round it but i get the feeling it could be something daft. (last thing, it drivesbetter when cold, although i never WOT before its up to temp. )
    Many thanks
  2. hades-
    9,480
    646
    MAP ?
    i had this on my fsiT some time ago ended up been a bad MAP sensor
    (no fault codes showing)
  3. spider74
    spider74 Member
    106
    10
    thanks Bez, i'll start with that one then! Where is it in the TFSI? im assuming on the intercooler piping post turbo? Is it the same thing as the boost pressure sensor? I'll have a search. Thanks for helping :)
  4. hades-
    9,480
    646
    yes i think its the same thing
    off hand im sure its down the pass side to the front near the headlight
  5. spider74
    spider74 Member
    106
    10
    ah well put the new map sensor in last night and although i was determined to feel it was fixed it isnt :( however you live and learn as im certain its temperature related. when cold even when the temp needle is at 90 but the oil temp perhaps isnt up to full temperature things are smooth. Im going to try the coolant tempera
  6. jonny87
    jonny87 Active Member
    1,094
    Pre cat/post cat lamdas?
  7. spider74
    spider74 Member
    106
    10
    got cut off half way through my message, meant..
    try the coolant temperature sensor, fuel temp sensor, manifold air temp sensor and possibly MAF again. Managed to persuade my mate whose wife has a 2.0tfsi to let me try a few from her car to help the process. MAP sensor was a good call though BEZ as its made a difference.
    Also the lambdas i have two one pre cat and oene post however the post is mapped out as i have no cat so i suppose i could swap them round? see if that helps? Thanks for the help folks, as i say the car runs ok just not right. v frustrating that it throws no codes. However thats why this forum is so great at helping us to avoid the £100 per hour Audi charges! :)
  8. mancdan
    mancdan Active Member
    475
    49
    What doe MAP stand for?
  9. Michaelkirkup
    Michaelkirkup New Member
    Map is manifold absolute pressure mate
  10. mancdan
    475
    49
    Cheers Michael.
  11. prel2000
    prel2000 Member
    67
    I'll be interested to see which action resolves your issue as I am experiencing similar symptoms with mine. Thanks
  12. Scott.T
    Scott.T Well-Known Member
    733
    277
    Has this been resolved yet as I'm chasing a 1,700rpm to 2,300rpm light missfire that flags no codes and it's not coil, plugs, MAF, DV of throttle pot. Throttle Body has also been cleaned.
  13. hades-
    9,480
    646
    have you checked the HPFP cam follower ?
  14. Scott.T
    733
    277
    No, is this easy to do.
    I have heard of it wearing but no idea where to locate it, other then down the back of the engine somewhere.
    Does this also increase the engine rattle when worn, as it may be another sympton.
  15. hades-
    9,480
    646
  16. Scott.T
    733
    277
    Cheer's had a google to and it seems quite straight forward.
    Would like to know what the symptons and side effects are.
  17. spider74
    spider74 Member
    106
    10
    Took me ages to get to the bottom of this but it was the thermostat. Car was running cold. £30 part. I also replaced the cts which showed up the problem more (old sensor might have been bad) and then logged engin temps with vcds. Temp fluctuated between 60 and 80 deg even on a long run.
