Which PIN (Pin Number) Will Move The Shutter? ? On the Bi-xenon LED Headlights
KemiksiZ Aug 15, 2012
  1. KemiksiZ
    KemiksiZ Active Member
    570
    142
    43
    I matched the old HIGH beam wire to the Pin 8 ( according to the given elsawin scheme ) but it wont move the shutter coz I did not use the original ballasts..
    So I have to know which pin will move the shutter.. I'll be heading to a long travel during the nigght, so I need my high beams desperately :s :)
    I bought the converter from ebay but it wont be ready for tomorrow..
    Any helps again, as always? :)
  2. Ash187
    7,505
    748
    Did you previously have bi-xenons? if you didnt then you would need to wire in the shutters into your CE module and code the car to suit it.
    If you did have it then it should just work.
  3. KemiksiZ
    570
    142
    43
    Nope Ash, I did not have it before.
    But the adaptors from Germany has just arrived. So I'm going to undo everything and just plug the plugs to each other. But just incase;
    from the CE unit, which one will be re-wired and directed to the which one?
    ThanksASH, you are the man, really ! :)
  4. Ash187
    7,505
    748
    here you go mate, follow this guide for the installing of Bi-xenons into prefacelift cars: Fourtitude.com - BiXenon Wiring & Coding
    dont get caught up on the fact that you are installing facelift LEDs as that doesnt matter for your car. as long as you have the correct wiring adapter it should all fit and work fine.
  5. KemiksiZ
    570
    142
    43
    Thanks a lot, We will see tomorrow :)
  6. NHN
    29,532
    1,768
    I just cant understand this at all, why would you goto all that trouble of facelifting, to then whack some cheap dirty adapter set in, surely with the work done already the guys doing the job could of rewired it all for you?
