  1. Harribo66
    Harribo66 Member
    163
    Sorry to sound daft but I have checked my manual, but cannot find what spec oil I need.
    i have a 1.9tdi 130.
    For some reason I have 5w30 in my head?
    any one tell me the correct oil to use?
  2. mikeyboy
    mikeyboy S-line
    431
    51
    Your 100% correct castrol 5W 30
  3. Harribo66
    Harribo66 Member
    163
    Ok thanks for that mikeyboy.
  4. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    Not just any 5/30 make sure its meets the vag spec
  5. A3_130
    A3_130 Member
    85
    I use 5W40 fully synthetic from Europarts or Car parts for less which is recommended for PD engines (mine's the PD 130 as well) and it's only about £30 for 5 litres.
  6. Harribo66
    Harribo66 Member
    163
    so 5w40 will be better then 5w30 ?
  7. scottshere
    scottshere Member
    369
    17
    I use 5w30. Didnt know you could use 5w40
    Surely the 5w40 is thicker and will take longer to react all the engine
    I use Castrol Edge and find this very good, need to search around for the best deal (google :yes:)
  8. stu_m
    1,441
    If you read the manual there is a different range of viscosity you can use
  9. Harribo66
    Harribo66 Member
    163
    Yeah I have seen them, lets hope the oil will state what viscosity it is!
  10. swarcup
    swarcup Well-Known Member
    1,326
    40
  11. I used Platinum 5w40 bought from TPS, which was recommended for fixed service intervals, Just under £20 for 5litres if i remember rightly,
  12. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    5-30 fully synth is the way to go,
