Which lowering springs?
mattyb6 Jun 3, 2014
  1. mattyb6
    mattyb6 Active Member
    977
    75
    Long story short as I went to replace a top mount today and heighten the from coil overs
    The coil overs are seized solid!!
    So I've decided I'm going to go the springs and shocks route with b5 perches
    But what lowering springs are people running?
    And what updated shocks if you are running them?
    I know quattrojames had the eiback kit I believe
    Should I upgrade the shocks?
    I've renewed all the arms, drop links and top mounts on the front.
    I will be doing the rear with a rs4 RARB when I do the springs
  2. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Eibach or Weitec springs for me. The Weitec spring and damper kit is very good and can highly recommend if you change the lot.
  3. mattyb6
    977
    75
    Cheers mike
    What sort of price range we looking at here?
    Any recommended dealers?
  4. Mike.M
    2,510
    170
  5. mattyb6
    977
    75
    Ah right, il have a look.
    If not il price from DPM, if the springs and dampers are too expensive il just get springs.
  6. Gazwould
    Gazwould Well-Known Member
    5,657
    2,295
    It's a common money cost cutting mistake not to get new dampers.
  7. DPM
    DPM Site Sponsor Site Sponsor
    5,063
    224
    Just to note, Weitec has now been discontinued and replaced with ST by KW.
    Damian @ DPM Performance
  8. mattyb6
    977
    75
    I know that, but would standard dampers and lowered springs be still okay?
    I would replace the shocks anyway but depends on price wether is standard with springs or unrated springs and dampers
  9. barkclark
    barkclark Well-Known Member
    1,011
    218
    I read somewhere that eibach springs are the same (or very similar) compression rate to standard sport springs. So they should work fine with OEM dampers. Anyone with further knowledge can confirm or correct this haha
  10. mattyb6
    977
    75
    I know, the lad who has the white avant thread going used eiback springs on OEM dampers which what got me thinking
  11. barkclark
    1,011
    218
    I've been planning eibach pro's for a while. Just needing to get new dampers and other bits and pieces before I get them fitted!
  12. mattyb6
    977
    75
    So you going OEM dampers or up rated?
  13. barkclark
    1,011
    218
    I'll stick with OEM mate
  14. Gazwould
    5,657
    2,295
    What model is your car ?
  15. mattyb6
    977
    75
    It's an 03 1.9tdi saloon FWD
  16. Gazwould
    5,657
    2,295
    Sport, SE etc ?
  17. mattyb6
    977
    75
    SE mate
  18. barkclark
    1,011
    218
    Correct me if I'm wrong but I'm under the impression that only OEM sport dampers will work with eibachs. Not OEM SE dampers.
  19. Gazwould
    5,657
    2,295
    With Eibach Pro or similar go with OE Sport shocks such as Bilstein B4 or Sachs Super Touring.
    Don't use standard OE SE shocks.
  20. ruffrida
    ruffrida Well-Known Member
    1,930
    313
    Yeh sports dampers and Eibach springs you will be sound !!
  21. mattyb6
    977
    75
    So the likes of ECP will sell these, as s-line models will have these as standard
  22. jbcalvin
    jbcalvin Member
    691
    21
    Following on from my night and day post, I really cannot recommend the Bilstein/Eibach combo I fitted last week highly enough, and when an Audi mastertech with 20+ years experience says the difference is night and day from my OEM Sport set up, that's good enough for me....
    Not cheap, but you pays your money etc etc.....
    Cheapest I could find was from Awesome GTI......
  23. peteh
    peteh Member
    46
    Don't happen to know the part numer do you, as there's loads of um!! Lol
    also some pics with um fitted? Really wanting this kit myself, but so confused at the mo as there's so many options about at the mo....
  24. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,746
    165
    QuattroJames ran eibach pro sport springs on OE SE shocks and reported no problems at all. So it is do-able.
  25. barkclark
    1,011
    218
    Ah I knew someone would be along to correct me! Good news for SE owners!
  26. Gazwould
    5,657
    2,295
    Do -able , but I seriously wouldn't recommend it.
    Eibach Pro kit spring will be more uprated than a OE Sport or S line spring.
    Sport or S line springs are more uprated than SE springs.
    Eibach spring really should have the stronger Sport dampers to control it.
  27. quattrojames
    14,062
    583
    I realise it's no ideal, but I can genuinely say I did it for 18 months + with no ill effects at all.
  28. jbcalvin
    jbcalvin Member
    691
    21
    Call the guys at Awesome and let them speak to Bilstein, it took over a week for mine to arrive as Bilstein had produced a superceeded part number..... I have no idea what mine is......
  29. mattyb6
    977
    75
    Been offered some eibach springs for £100 of a forum member, but there from a Quattro so don't know if they'll fit or if any has done Quattro springs on a fwd and what the differences, if any, are?
    I'm going to attempt again, to free my coilover collars on Saturday if not, il be getting some eibach sprins with s-line springs as I won't be able to afford the full kit with dampers.
    If I can free them il be laughing as the car won't be scraping anymore and by the time I get a rs4 rarb on be even better.
    I'm keep you's updated anyway
  30. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    263
    Soak them with plusgas (or wd40 if you can't get any) a couple of times a day for a few days, then take a hammer and chisel to them mate.
  31. Jimmy TDI
    1,320
    263
    Also try tapping them both ways to loosen them up
  32. barkclark
    1,011
    218
    Lucky sod!
    mattyb6 likes this.
  33. jbcalvin
    jbcalvin Member
    691
    21
    As far as I am aware, quattro springs will not work with a FWD, more weight at the back with diffs etc so the spring rates will be completely different.....
  34. S4_dan
    2,746
    165
    I've got some eibach pro sport kit springs for sale in the classifieds section.
    Dan
  35. rbailey88
    rbailey88 Active Member
    132
    29
    Ive got a set of dampers off my 1.8t 190 s-line in the garage if any use? 30 quid if you want them mate
  36. mattyb6
    977
    75
    Thanks for the offer mate but no thanks
    The engineers at work are going to sort my coilovers out for free. :)
    So can't complain really, then il see what situation I'm in after that
  37. Duck
    Duck Member
    46
    Who is it selling the Eibach Quattro springs?
  38. mattyb6
    977
    75
    S4 dan mate
